how to manual adjust cef load sharing
n.bokhar1
hi
i need to manually adjust cef load sharing and maybe turn it off on some interfaces (without turning off cef) or use load sharing like 4 on one link and 1 on another link
I don't think you can use 40:60 ratio load via CEF . However if you want to turn off cef (and keep it enabled globally) then use below on those specific interfaces-
-> no ip route-cache
-> no ip cef
