Why ip overlaps ?
Juliusvar1
Hello guys, I faced with problem.
R1
int f0/0
ip add 192.168.100.1 255.255.255.252
int f0/0.100
encapsulate do1q 100
ip add 192.168.100.254 255.255.255.0
SW
vlan 100
int f0/1
switchport mode trunk
switchport trunk allow vlan 100
int fa0/2
switchport mode access
switchport access vlan 100
spanning tree portfast
Can someone explain why when I try put ip address on R1 fa0/0 192.168.100.1 and trying to encapsulate IP address 192.168.100.254 I receive that overlapsing int f0/0
2 Accepted Solutions
192.168.100.0/22 (or 192.168.100.0 255.255.255.252) is in the same address space as 192.168.100.0/24 (or 192.168.100.0 255.255.255.0), so you get an error.
Basically, if you use an /24 address space on one interface, you cannot use any of the subaddresses in that address space on any other interface on the same router.
If you convert both IP addresses and subnet masks to binary, you can see that the last octet (all zeros) in the /24 address covers all addresses in that space:
11000000.10101000.01100100.00000001 11111111.11111111.11111111.11111100
11000000.10101000.01100100.00000001 11111111.11111111.11111111.00000000
Does that make sense ?
Hello
@Juliusvar1 wrote:
R1
int f0/0
int f0/0.100
192.168.100.254/24  = 192.168.100.1-254 addressing
192.168.100.1/252  = 192.168.100.1-2 addressing <--- this overlaps with the above
Kind Regards
Paul
I got it. Thank you !
Seb Rupik
Hi there,
int fa0/0 (/30) overlaps with the subnet assigned to fa0/0.100 (/24).
If you wanted to continue using these IP addresses then you would need to put the interfaces in separte VRFs.
Or you could reduce the subnet size for fa0/0.100 :
int f0/0.100
  ip add 192.168.100.254 255.255.255.128
cheers,
Seb,
Hello
@Juliusvar1 wrote:
R1
int f0/0
int f0/0.100
Kind Regards
Paul
