How to measure throughput on Cisco 2811
ciscobigcat
How do you measure the current throughput on a Cisco 2811 router?
We will be replacing this unit with a 4000 series one but the new devices limit the amount of throughput and require a license to increase the limit.
Also, anyone aware of the commands to check the current throughput limit on a 4000 series router?
thank you guys in anvance
c
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
How to measure 2811 throughput?  Note aggregate of all interface bit rates with CPU usage.
I'm not sure about the 4K, but a show license might show the active license, and if it does, that should tell you the maximum performance.
