How to Monitor IP Traffic on Switch..
vipin kumar
Dear All,
I am new on cisco technology. I have a core switch of 4500 series. some system are generating the traffic Extra LAN traffic. how i can monitor on switch that which system is generating the traffic,
thanks in advance
Latchum Naidu
Unfortunately, ip accounting is not supported on 4000 & 4500 series platforms... I have attached a doc, which gives the software features supported for one of the extended IOS versions of SUP IV... 4500 series have an advance feature called Netflow, which you can use for troubleshooting purpose.. but for that i guess you need to have the netflow daughter card installed on your supervisor engine...
You can also have a look at the datasheet of SUP IV to know more on netflow...
http://cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd8035cf2b.html
Hope this helps you...
Please rate the helpfull posts.
Naidu.
