I have a 800-Series router connected in the following configuration:
Port GigabitEthernet7 is connected to an external server (192.0.2.251) that sends unicast UDP to destinations 192.0.2.42:45100 and 192.0.2.44:45100
Port GigabitEthernet1 is connected to two internal servers (via a bridge) with addresses 192.168.210.31 and 192.168.210.32
The two internal servers are supposed to receive the same data received on GigabitEthernet7. The source address in the received packets should be 220.120.121.120
The following configuration is used:
ethernet lmi ce
ip cef
no ipv6 cef
interface Loopback1110
ip address 220.120.121.120 255.255.255.0
ip nat enable
interface GigabitEthernet1
description Internal_Network
switchport access vlan 2
no ip address
interface GigabitEthernet7
description External_Network
switchport access vlan 3
no ip address
interface Vlan2
ip address 192.168.210.250 255.255.255.0
ip directed-broadcast
ip nat enable
ip virtual-reassembly in
interface Vlan3
ip address 192.0.2.250 255.255.255.0
ip nat enable
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat source list NATT interface Loopback1110 overload
ip nat source static udp 192.168.210.255 45100 192.0.2.42 45100 extendable
ip access-list extended NATT
permit ip 192.0.2.0 0.0.0.255 any
I configured my laptop with address 192.168.210.211 and connected it to GigabitEthernet1 and sniffed data (using Wireshark). However, nothing is received. However, when I change the second NAT line above to
ip nat source static udp 192.168.210.31 45100 192.0.2.42 45100 extendable
I successfully receive data on the unicast address 192.168.210.31.
What I need is to receive data by both servers connected to that port.
PS:
I tried ip forward-protocol nd but didn't get a different result.
I also tried ip multicast-routing but the same result.
