ROMMON Update fails from 16.7 to 16.12 at ISR4351/K9
Hi Community.
This is my first time with a Cisco Product, and we are just running into a Problem. We would like to flash a Firmware to the ISR 4351/K9 Router. It starts, but after the procedure is finished and we use the reload, after booting, the old Firmware is still displayed. Here are the details of the upgrade Procedure:
Router>en
Router#upgrade
Router#sh platform
Chassis type: ISR4351/K9
Slot Type State Insert time (ago)
0 ISR4351/K9 ok 18:48:19
0/0 ISR4351-3x1GE ok 18:46:32
0/1 NIM-VA-B ok 18:46:32
1 ISR4351/K9 ok 18:48:19
2 ISR4351/K9 ok 18:48:19
R0 ISR4351/K9 ok, active 18:48:19
F0 ISR4351/K9 ok, active 18:48:19
P0 PWR-4450-AC ok 18:48:01
P2 ACS-4450-FANASSY ok 18:48:01
Slot CPLD Version Firmware Version
0 17100927 16.7(3r)
1 17100927 16.7(3r)
2 17100927 16.7(3r)
R0 17100927 16.7(3r)
F0 17100927 16.7(3r)
Router#upgr
Router#upgrade rom-
Router#upgrade rom-monitor filename?
filename
Router#upgrade rom-monitor filename boot
Router#upgrade rom-monitor filename bootflash:?
bootflash:.dbpersist
bootflash:.installer
bootflash:.prst_sync
bootflash:.rollback_timer
bootflash:core
bootflash:gs_script
bootflash:isr4200_4300_rommon_1612_2r_SPA.pkg
bootflash:isr4300-universalk9.16.09.02.SPA.bin
bootflash:isr4300-universalk9.17.06.03a.SPA.bin
bootflash:lost+found
bootflash:nbar2
bootflash:nbar2_http_default.tar
bootflash:onep
bootflash:startup-config
bootflash:sysboot
bootflash:throughput_monitor_params
bootflash:tracelogs
bootflash:virtual-instance
% Incomplete command.
Router#upgrade rom-monitor filename bootflash:isr4200_4300
Router#$-monitor filename bootflash:isr4200_4300_rommon_1612_2r_SPA.pkg R0
Chassis model ISR4351/K9 has a single rom-monitor.
Upgrade rom-monitor
Target copying rom-monitor image file
Booted : 0
Selected : 0
Reset Reason: 0
Switching to ROM 1
Upgrading ROMMON image...
4194304+0 records in
4194304+0 records out
4194304 bytes (4.2 MB, 4.0 MiB) copied, 254.327 s, 16.5 kB/s
4194304 bytes (4.2 MB, 4.0 MiB) copied, 27.5907 s, 152 kB/s
Verifying ROMMON image...
4194304 bytes (4.2 MB, 4.0 MiB) copied, 25.0503 s, 167 kB/s
Switching back to ROM 0
ROMMON upgrade was successful...
Copying ROMMON environment...
262144+0 records in
262144+0 records out
262144 bytes (262 kB, 256 KiB) copied, 1.07379 s, 244 kB/s
Switching to ROM 1
Updating ROMMON environment...
262144+0 records in
262144 bytes (262 kB, 256 KiB) copied, 15.6534 s, 16.7 kB/s
262144+0 records in
262144 bytes (262 kB, 256 KiB) copied, 1.58116 s, 166 kB/s
ROMMON Variable data passed verification check (1).
ROMMON upgrade complete.
To make the new ROMMON permanent, you must restart the RP.
Router#
We are confused about that it will switch to ROM1, because the Router has only one BIOS, and that is R0.
Hopefully, there is anyone of you Guys, is able to help me.
Andreas
7 Replies 7
balaji.bandi
When you upgrade from older image to new image ROMMON will upgrade will be done.
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/release/xe-16-12/isr4k-rel-notes-xe-16-12.html#con_176427
BB
Hi Balaji Bandi.
I have startet the Update using 'upgrade', but it allways results in that only ROM1 will be upgraded, and ROM0 keeps the old Version of the ROM.
Best Regards,
Andreas
Can you post
show version
show platform
BB
Router#sh platform
0 ISR4351/K9 ok 00:07:20
0/0 ISR4351-3x1GE ok 00:05:35
0/1 NIM-VA-B ok 00:05:35
1 ISR4351/K9 ok 00:07:20
2 ISR4351/K9 ok 00:07:20
R0 ISR4351/K9 ok, active 00:07:20
F0 ISR4351/K9 ok, active 00:07:20
P0 PWR-4450-AC ok 00:07:02
P2 ACS-4450-FANASSY ok 00:07:02
0 17100927 16.7(3r)
1 17100927 16.7(3r)
2 17100927 16.7(3r)
Router#show version
Cisco IOS XE Software, Version 16.09.02
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 05-Nov-18 19:31 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 7 minutes
Uptime for this control processor is 9 minutes
System returned to ROM by Reload Command
System image file is "bootflash:isr4300-universalk9.16.09.02.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None Smart License None
securityk9
appxk9
AdvUCSuiteK9 None Smart License None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None Smart License None
uck9 uck9 Smart License uck9
securityk9 securityk9 Smart License securityk9
ipbase ipbasek9 Smart License ipbasek9
The current throughput level is 400000 kbps
Smart Licensing Status: UNREGISTERED/EVAL MODE
cisco ISR4351/K9 (2RU) processor with 1784726K/6147K bytes of memory.
Processor board ID FDO2239A08W
1 Ethernet interface
3 Gigabit Ethernet interfaces
1 ATM interface
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
4096000K bytes of USB flash at usb0:.
0K bytes of WebUI ODM Files at webui:.
Configuration register is 0x2101
Are you able to help me using a remote Session, please? I can provide you with a session ID. For update of the BIOS (ROM), I will pay 50 USD to your PayPal Account.
Leo Laohoo
That command is wrong.
upgrade rom-monitor filename bootflash:isr4200_4300_rommon_1612_2r_SPA.pkg all
Hi. I tried both. Upgrade with R0 and also Update with all. But now after the Autoupdate starts, it cant finish the Job, because there are to many Jobs in the Que. How can I clean up the Que, please?
Andreas
