How to ping all interface ATM within the POP
 I would like to ping all interfaces on the POP Cisco. What is the command that from this output?
Interface
VPI
VCI
status
ping atm
rtt ping atm
2/0.131
13
110
up
(500/500)
1/1/276 ms
2/0.129
13
125
up
(500/500)
1/4/296 ms
2/0.900
13
139
up
(500/500)
1/1/16 ms
2/0.183
16
118
up
(484/500)
1/18/76 ms
2/0.180
16
133
up
(482/500)
1/20/288 ms
2/0.213
16
135
up
(480/500)
1/20/296 ms
2/0.243
16
136
up
(483/500)
1/20/320 ms
2/0.212
16
137
up
(477/500)
1/24/312 ms
2/0.248
16
138
up
(487/500)
1/24/352 ms
2/0.148
16
150
up
(481/500)
1/20/336 ms
2/0.621
16
151
up
(485/500)
1/19/308 ms
2/0.204
16
152
up
(489/500)
1/17/112 ms
2/0.204
16
153
up
(479/500)
1/16/276 ms
2/0.215
16
154
up
(486/500)
1/17/80 ms
2/0.214
16
157
up
(488/500)
1/27/320 ms
2/0.132
16
163
up
(485/500)
1/16/308 ms
2/0.947
16
164
up
(487/500)
1/16/80 ms
2/0.162
16
165
up
(490/500)
1/20/320 ms
2/0.909
16
166
up
(486/500)
1/17/276 ms
2/0.198
200
48
up
(500/500)
1/1/36 ms
2/0.229
200
62
up
(500/500)
1/1/8 ms
2/0.945
200
69
up
(500/500)
1/1/20 ms
2/0.912
200
76
up
(500/500)
1/1/22 ms
10 Replies 10
Mark Malone
Hi you would need to build a TCL script and add all the ip addresses to it to ping all interfaces at once ,
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ios_tcl/configuration/12-4t/ios-tcl-12-4t-book/nm-script-tcl.html
Thanks for your support,
but can you help me to create a tcl script to ping all ip.
Do you have a tcl script ready ?
Thank and good job!
Hey
Here is an example of what to do , you will need to replace the ip address with your own ips obviously , you change how many pings and the source with this script
First enter tclsh in priv mode then use the script below as it is in bold but change the ips , you can have as many as you want , tclquit to break out of router script mode
RouterC1DE44(tcl)#foreach test {
+>172.20.15.251
+>172.20.19.251
+>172.20.23.251
+>172.20.39.249
+>} {ping $test re 3 time 1 source vlan1226}
Sending 3, 100-byte ICMP Echos to 172.20.15.251, timeout is 1 seconds:
Packet sent with a source address of 172.20.226.118
Success rate is 100 percent (3/3), round-trip min/avg/max = 1/3/9 ms
Sending 3, 100-byte ICMP Echos to 172.20.19.251, timeout is 1 seconds:
Success rate is 100 percent (3/3), round-trip min/avg/max = 1/1/1 ms
Sending 3, 100-byte ICMP Echos to 172.20.23.251, timeout is 1 seconds:
Sending 3, 100-byte ICMP Echos to 172.20.39.249, timeout is 1 seconds:
xco-d110nis01(tcl)#
Perfect, thanks you
but how do this command to script:
ping atm interface atm 1/0.25 Vp Vc seg-loopback
Its an ip based scripting command its not possible to use the script like that
you would have to have the loopback ip address first and add it to the script enter tcl section of IOS and then run it
This is not a Cisco command its a programming language TCL that exists inside most Cisco devices that Cisco allows to be used in their IOS.
Ok could you explain me how to do on  the router?
If your still not sure you can post the ips and I will put them in the script for you
This is my ip ping:
10.251.12.126
172.31.20.218
10.251.43.178
172.31.250.142
10.251.9.162
172.16.103.182
10.251.45.38
10.251.9.214
10.251.22.238
10.251.12.38
10.160.9.146
10.251.9.118
Change your source below that's highlighted to something on your router looback or another ip interface ,then copy this exactly into your router in privileged mode and then hit return that's it
tclsh
foreach test {
10.251.12.126
172.31.20.218
10.251.43.178
172.31.250.142
10.251.9.162
172.16.103.182
10.251.45.38
10.251.9.214
10.251.22.238
10.251.12.38
10.160.9.146
10.251.9.118
+>} {ping $test re 4 time 1 source vlan1226}
Thanks you, you are my good friead ahahahha
Goodbye and good job
