how to recovery password
wanglei
if i configue this command:no service password-recovery .
then when i lost my password ,how can i recovery password,if it will process in normal?
thank you very much!
ankurbhasin
Level 9
Level 9
Hi Friend,
Make sure before configuring this command you take the backup of your config and also if switch is in vtp transparent mode Cisco recommend that you also save a copy of the vlan.dat file in a location away from the switch.
When the password-recovery mechanism is disabled, interrupting the boot process is allowed only if the user agrees to set the system back to the default configuration.
Also have a look at this link for complete usage guidelines
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tsec_r/sec_s1ht.htm#wp1258224
HTH, if yes please rate the post.
Ankur
ankurbhasin
Level 9
Level 9
Hi Friend,
Ankur
