IOS version for Cat4503
att-sgcops
when we tried to upgrade our Cat4503 IOS using IOS upgrade planner tools, we saw there are 2 versions we like to select:"
12.2.31-SG and 12.2.25-EWA5" but the problem is: 12.3.31-sg support SSH, while 12.2.25-EWA5 support L3 routing, can we have these 2 features both?
thanks for reply.
jolmo
Level 4
Level 4
According to Software Advisor, 12.2.25-EWA5 BASIC L3 3DES Feature supports SSHv1 and SSHv2 and basic L3. You can also see this info here:
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_release_note09186a00801f5b1e.html#wp618071
