How to register smart license in ISR4331 with IOS13.3.4
Smile丶
Hi everyone,I have a problem about register smart license in ISR4331 with IOS17.3.4.
I cant use the command"license samrt register idtoken <token>",this command is unavailable,so how should I to do?Is there any other ways to complete it?
ISR4331#license smart ?
  authorization  Authorization
  clear          Clear
  export         Get or return an export authorization key
  factory        Execute Smart Licensing Factory commands
  import         Import authcode, policies, trustcode etc
  save           Save
  sync           Sync with CSLU/CSSM.
  trust          Establish trust between PI and CSLU/CSSM.
like this post,I cant find the command of register.
6 Replies 6
do you have connectivity to tools.cisco.com from this router? also try enabling smart license before registering.
https://www.cisco.com/c/en/us/td/docs/routers/access/isr4400/software/configuration/xe-17/isr4400-sw-config-xe-17/smart_licensing.html#concept_FFF9EA63B9884E28ADC1C965FF70B863
Good luck
KB
thanks for your reply. Yes, I have enabled. but there are have no this command ,in other router we can see it.
ISR4221#lic smart ?
  clear       Clear
  deregister  deregister this device
  register    register token id
  renew       Smart License renew
  send        license smart send
what is the OS version of other router?
Good luck
KB
it is 16.9.3
For routers, Cisco Smart License is supported from 16.10.X (and later).
yes,my version is 17.3.4, I have creat a token from the smart account, but in the device I perform "license smart register idtoken <token>" this command is not available,but in another device which run ios 16.9.3 I can perform this command, so I dont know how to do,is there any other way to register smart license in ios 17.3.4? the follw is my CLI information
  clear          Clear
  save           Save
