ASR1001-X does not store its config
manuelcalderon
Hello all,
My Cisco Router ASR1001 doesn't store the configuration when I type the write (or copy running-config startup-config). When I reset the device it is configurated defaultly. Do you know if this problem has a solution without sending it to repair?
Thanks in advance!!
balaji.bandi
Can you post -
show version
check config register
https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/50421-config-register-use.html
BB
balaji.bandi
Can you post -
show version
BB
Joseph W. Doherty
Besides checking config-reg (@balaji.bandi's has all the details), can you see your start-up config?
manuelcalderon
You were right!! The configuration register was incorrectly set, so I put it in 0x2102 and now the configuration is correctly stored in the startup-configuration. Thanks!!!!!!!!!!!!!!
