how to run class-map under policy-map.
syjeon
Hi Alls,
I have some concerns, if we consider QoS, we can configure QoS as following for instance.
policy-map **name**
  class **name_A**
   set dscp default
   class **name**
   set dscp af20
  class **name_B**
  queue-limit 8192
   service-policy **name_c**
under above condition, Does two classes work arranged in a row(line) or in order ?
AJ Cruz
Level 3
Level 3
I'm not sure I understand the question. This looks like an inbound policy to mark traffic. If the traffic doesn't match the logic of the first class it will try the next until it eventually falls through to the "class-default" class (assuming no match was found.
Sent from Cisco Technical Support Android App
