How to See What OSPF Redistributes
rookie R
Hi all!
I have a couple of questions regarding ospf route redistribution:
1. How can I determine which ospf routers are being redistribute into other protocols? First, I  thought  show ip route would give me the answer, but apparently not. For example, the route to 22.22.22.22 appears as a static\connected route in the routing table. so would 'show ip ospf database' help in this case?
2.what exactly does ospf redistribute into other protocols? I assume maybe it's based on the LSAs?
3.can I use 'show ip route eigrp' to see which eigrp routes are being redistributed into other protocols? Similary, can I use show ip bgp to find out which BGP routes are being redistributed?
Below is the configuration of R2 for reference:
R2#show run
Building configuration...
Current configuration : 1228 bytes
! Last configuration change at 19:57:53 CST Sat May 24 2025
version 15.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone CST 8 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip domain lookup
ip cef
no ipv6 cef
redundancy
interface Loopback0
 ip address 2.2.2.2 255.255.255.255
interface Loopback5
 ip address 22.22.22.22 255.255.255.255
interface Ethernet0/0
 ip address 192.168.12.2 255.255.255.0
interface Ethernet0/1
 no ip address
 shutdown
interface Ethernet0/2
 no ip address
 shutdown
interface Ethernet0/3
 no ip address
 shutdown
router ospf 2
 network 22.22.22.22 0.0.0.0 area 0
router bgp 2
 --More--
*May 24 11:57:53.567: %SYS-5-CONFIG_I: Configured from console by console
 bgp router-id 2.2.2.2
 bgp log-neighbor-changes
 redistribute ospf 2
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
line vty 0 4
 login
 transport input none
end
R2#
R2(config-router)#do show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is not set
      2.0.0.0/32 is subnetted, 1 subnets
C        2.2.2.2 is directly connected, Loopback0
      22.0.0.0/32 is subnetted, 1 subnets
C        22.22.22.22 is directly connected, Loopback5
      192.168.12.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.12.0/24 is directly connected, Ethernet0/0
L        192.168.12.2/32 is directly connected, Ethernet0/0
R2(config-router)#do show ip ospf data
            OSPF Router with ID (22.22.22.22) (Process ID 2)
                Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
22.22.22.22     22.22.22.22     8           0x80000001 0x005BCD 1
R2#show ip bgp
BGP table version is 2, local router ID is 2.2.2.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
 *>  22.22.22.22/32   0.0.0.0                  0         32768 ?
Here is my configuration of the R2:
R2#show run
! Last configuration change at 20:11:43 CST Sat May 24 2025
version 15.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
redundancy
interface Loopback0
interface Loopback5
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router ospf 2
router bgp 2
redistribute ospf 2
no ip http server
control-plane
line con 0
--More--
*May 24 12:11:43.395: %SYS-5-CONFIG_I: Configured from console by console
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
line vty 0 4
login
end
R2#
Routing table:
OSPF database:
BGP routing table:
R2#show ip bgp
Thanks so much!
38 Replies 38
Mark Elsen
  - Check the output from :  show ip ospf 2
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hello
When a rtr running ospf receives/advertises routes via redistribution then that rtr becomes an ASBR  - basically an external border router between ospf and the other protocol (such as eigrp/bgp/isis)
to check the external routes of an ASBR you can check the Link State database (LSDB) for the advertised external LSAs
sh ip ospf database external = type 5 lsa =E1/2 routes
sh ip ospf database nssa-external = type7 lsa =N1/2 routes
Kind Regards
Paul
Technically, believe an ASBR needs to redistribute into OSPF.  If router is only injecting OSPF routes into another non-OSPF routing protocol, it's not an OSPF ASBR.
BTW, sometimes I've seen OSPF configurations, rather then including interface networks into OSPF, redistribute "connected".  Shazam, that router becomes an ASBR.  (I suspect this is done to avoid the "need" to configure an OSPF statement for every interface. [Also those that do this often seem unaware of some of the inherent. OSPF potential impacts.  Not necessarily bad, just possibility unappreciated.])
Joseph makes a very good point, that you can not look at OSPF and find what it is redistributing to other protocols. You need to look at other protocols running on the device and see what they are learning via redistribution from OSPF.
The OP also asks what exactly does ospf redistribute into other protocols, is it based on LSAs? It is really not based on LSAs. The redistributed information would include the prefix, prefix length, and next hop. Other fields in the LSA are specific to OSPF and would not be useful for EIGRP, BGP, etc.
The OP also asks can I use 'show ip route eigrp' to see which eigrp routes are being redistributed into other protocols. The answer here is similar to the first question. You can not look at routes in a routing protocol and determine what is being redistributed from the source. You must look at the receiving routing protocol and see what it is learning via redistribution.
Rick
The quoted "route table" kind of information I had in mind.
Other information is also often included as part of the redistribution but that's somewhat a translation or setting of similar information used by different routing protocols, such as metrics to determine the best path.  (This, too, can be an issue because different routing protocols can be very different in how they determine best path, and/or other topology considerations.)
Basically, redistribution is the information Rick describes, which is LCD for routing with additional information to satisfy the routing protocol being redistributed into.
Keep in mind, you could, concurrently, redistribute multiple sources into the same routing protocol, and, on the receiving end, nothing implicitly distinguishs the original source (kind).  For example, an EIGRP receiver could not distinguish between routes being redistributed from OSPF or BGP.  (However, we can sometimes explicitly tag routes being redistributed, so the receiver can distinguish between redistribution sources.)
Rick's 3rd paragraph is perhaps clearer than my "ditto #1".
Thanks so much. would you mind answering another question for me? I am trying to understand exactly which prefixes get redistributed by the routing protocols:
If I want to redistribute OSPF into EIGRP,and there are 6 LSAs in the OSPF database, can I say that the 6 routes generated by these LSAs are the ones being redistribute into EIGRP?
Similary, if I want to redistribute EIGRP into OSPF, and there are 6 entries shown in the 'show ip eigrp topology' command,can I assume that these 6 eigrp routes are the ones being redistribute into OSPF?
6 LSAs wouldn't necessarily provide 6 routes, I believe, but by default, whatever the redistribution router has, for routes, in its LSDB, should be sent to EIGRP.
Logically, this applies to any routing redistribution but cannot say for sure about EIGRP topology information.  For example, I assume a successor route known to EIGRP might be excluded during redistribution.  @Richard Burts , though, is very knowledgeable on EIGRP.
I touched on this before, but think of what the redistribution router would show for "show ip route", if it only had just a single source kind for its route table.  The latter avoiding conflicts, and AD resolution, for different route kind sources.
Also, I'm assuming route maps aren't being used.
Also, understand, redistribution routing protocol differences may impact what the recipient actually obtains.  (For example redistribution of OSPF networks into RIP which are not classful.)
Also, you are considering LSAs, but they are per LSDB, and Cisco allows multiple per router.  I recall (?) redistribution from OSPF might pull from all of them, but redistribution into OSPF is to a specific LSDB.
Did I mention, in an earlier reply, redistribution can be complex and it's easy to get wrong?
You ask an interesting question "exactly which prefixes get redistributed by the routing protocols". Unfortunately there is not a simple/direct answer for this. There are characteristics of the protocols which may affect what is redistributed, and certainly there are options available in the redistribute commands of the protocols that might affect what is redistributed. And Joseph has done a good job of explaining that there is not necessarily a one to one relationship of what you see in the routing protocol internal tables and routes that get redistributed.
Rick
You need two steps
1- show ip ospf db external
2- show ip route  ×.×.×.× <<- x.x.x.x is route you get from first step
This will show you from where this route' connect or redistrubte.
MHM
You need two steps
2- show ip route ×.×.×.× longest <<- x.x.x.x is route you get from first step
I believe you may have misunderstood OP (or I did).
If above not work' then try use tag when redistrubte eigrp into ospf' then check
Show ip route x.x.x.x <<- check tag to see which prefix redistrubte from eigrp into ospf
MHM
I believe you may still be misunderstanding what OP is asking (again assuming I correctly understand what's being asked).  Which I believe is, for example, if OSPF is redistributing into another routing protocol, is there an easy way to see what was sent to the other routing protocol (possibly limited to the redistribution router)?
What you've described are ways to see what OSPF has received from another routing protocol, and its source.
Further, I believe OP is interested in how to determine what will be redistributed into another routing protocol without even actually doing so.
'if OSPF is redistributing into another routing protocol, is there an easy way to see what was sent to the other routing protocol.'
That is what I want to know, but my English is too weak to express it correctly and precisely.The reason I've been asking all these questions is because i am trying to find an easy way to clearly see exactly which routes are being redistribute into another routing protocol, but it seems there is no single show command that get the job done.
In my opinion, if I redistribute ospf into another protocol on R1, no additional parameters like route-map, distribute-list, just a simple single 'redistribute ospf 1' command, all the routes that are generated by the routers in the ospf 1 process domain will be redistributed, can you tell me how far off i am?
Thanks for your funny and knowledgeable answer! It's far more than I expected. You're so knowledgeable and kind, and now I know I really need to work hard on understanding the concept of LSAs. By the way, I'm also a big fan of 'The Matrix'. I watched it again a few days ago, but since I'm not a native English speaker, I didn't quite get the 'red pill' reference when i read your reply the first time, I finally understood it with the help of GPT.
And to go off-topic a little bit too, my English is weak, and the concept of LSAs is difficult, so it took me days to process all the answers, and i am still in that process, thanks to all of you who commented on my question, you guys are the reason i want to keep learning because i know no matter what difficulties i face, you will be there to help, and i try to pass that kindness to others because i am helping others with their studies
I understood that, and, at least in this instance, I didn't find your English too weak.
I'm not aware of an easy way to that obtain information, at least within OSPF.  Might it be obtained at all?  I believe it's possible, more on that later.
You're not far off, I believe, but possibly it's more precise to say, it would be the routes known (within that router's LSDB) to the OSPF process, on the OSPF router, that's being actually doing the redistribution.
Above, I mentioned it might be possible to ascertain, on any OSPF router, what it would redistribute.  That, I believe, might be done by examination of the OSPF router's LSDB, analyzing the results of various show ip ospf database commands.
What follows are a couple of references to allow your own manual construction of the OSPF topology.  What you want to obtain, isn't quite as detailed, as you really don't want to recreate the topology, just identify the networks, but the references will show this may require issuing multiple commands and "computing the results"; again, not easy.
https://networklessons.com/ospf/how-to-read-the-ospf-database
https://community.cisco.com/t5/networking-knowledge-base/reading-and-understanding-the-ospf-database/ta-p/3145995
