How to See What OSPF Redistributes
rookie R
Hi all!
I have a couple of questions regarding ospf route redistribution:
1. How can I determine which ospf routers are being redistribute into other protocols? First, I  thought  show ip route would give me the answer, but apparently not. For example, the route to 22.22.22.22 appears as a static\connected route in the routing table. so would 'show ip ospf database' help in this case?
2.what exactly does ospf redistribute into other protocols? I assume maybe it's based on the LSAs?
3.can I use 'show ip route eigrp' to see which eigrp routes are being redistributed into other protocols? Similary, can I use show ip bgp to find out which BGP routes are being redistributed?
Below is the configuration of R2 for reference:
R2#show run
Building configuration...
Current configuration : 1228 bytes
! Last configuration change at 19:57:53 CST Sat May 24 2025
version 15.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone CST 8 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip domain lookup
ip cef
no ipv6 cef
redundancy
interface Loopback0
 ip address 2.2.2.2 255.255.255.255
interface Loopback5
 ip address 22.22.22.22 255.255.255.255
interface Ethernet0/0
 ip address 192.168.12.2 255.255.255.0
interface Ethernet0/1
 no ip address
 shutdown
interface Ethernet0/2
 no ip address
 shutdown
interface Ethernet0/3
 no ip address
 shutdown
router ospf 2
 network 22.22.22.22 0.0.0.0 area 0
router bgp 2
 --More--
*May 24 11:57:53.567: %SYS-5-CONFIG_I: Configured from console by console
 bgp router-id 2.2.2.2
 bgp log-neighbor-changes
 redistribute ospf 2
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
line vty 0 4
 login
 transport input none
end
R2#
R2(config-router)#do show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is not set
      2.0.0.0/32 is subnetted, 1 subnets
C        2.2.2.2 is directly connected, Loopback0
      22.0.0.0/32 is subnetted, 1 subnets
C        22.22.22.22 is directly connected, Loopback5
      192.168.12.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.12.0/24 is directly connected, Ethernet0/0
L        192.168.12.2/32 is directly connected, Ethernet0/0
R2(config-router)#do show ip ospf data
            OSPF Router with ID (22.22.22.22) (Process ID 2)
                Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
22.22.22.22     22.22.22.22     8           0x80000001 0x005BCD 1
R2#show ip bgp
BGP table version is 2, local router ID is 2.2.2.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
 *>  22.22.22.22/32   0.0.0.0                  0         32768 ?
Here is my configuration of the R2:
R2#show run
! Last configuration change at 20:11:43 CST Sat May 24 2025
version 15.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
redundancy
interface Loopback0
interface Loopback5
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router ospf 2
router bgp 2
redistribute ospf 2
no ip http server
control-plane
line con 0
--More--
*May 24 12:11:43.395: %SYS-5-CONFIG_I: Configured from console by console
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
line vty 0 4
login
end
R2#
Routing table:
OSPF database:
BGP routing table:
R2#show ip bgp
Thanks so much!
38 Replies 38
Starting from this I have several suggestions "'if OSPF is redistributing into another routing protocol, is there an easy way to see what was sent to the other routing protocol"
- there are ways to identify what has been redistributed, but I don't think they are easy.
- I like the articles that Joseph identified. But if we are looking for what routes have been redistributed from OSPF, we will not find the answers by looking in OSPF. We need to identify what other routing protocols are running on the device and look into those protocols.
- and if we want to be really sure of what has been redistributed from OSPF, we probably need to look on neighbor routers running that other protocol and look for routes that originated in OSPF of your first router.
Rick
BTW, the reference articles were just examples of dissecting the OSPF LSDB, to obtain the topology known to that particular OSPF router.  OP, though, is only asking for a subset of that information, i.e. routes, but OSPF's LSDB has them too.  I.e. similar effort, not the specific effort.
Since OP is looking for the routes that would be redistributed by an OSPF router, @Richard Burts are you saying, that OSPF router does NOT have those routes in its LSDB?  If not, where would that information be?  (In theory, OSFP networks local to that router could be stored elsewhere [not in the LSDB], although I suspect that's not the case [because LSDB is, selectively, "redistributed" to adjacent OSPF router(s)].  If stored in addition to the LSDB, that's likely possible, for example LSDB feeding RIB, like a show IP route, showing only better AD routes, like local networks as "connected" but not OSPF, although known to OSPF [if desired, I can show a simple example using PT].)
As to seeing redistributed routes, after they've been redistributed, much would depend on how the receiving routing protocol accepts them.
@Joseph W. Doherty wrote:
Technically, believe an ASBR needs to redistribute into OSPF.  If router is only injecting OSPF routes into another non-OSPF routing protocol, it's not an OSPF ASBR.
Hello Joseph
Would you say an ABR of an NSSA ASBR area is ALSO an ASBR due to it performing type7-5 translation?
Kind Regards
Paul
Paul, I would say a NSSA ABR not the original source of the external route is not an ASBR, i.e. type 7 to 5 translation, alone, isn't sufficient.
Believe this Cisco TechNote, https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/6208-nssa.html is the same understanding.
Of course, though, an ABR can also be an ASBR, including for a NSSA ABR, which is also shown in the above reference (compare the two network diagrams).
Do you have reason to believe otherwise, such as, perhaps how Cisco's OSPF displays 7 to 5 translated routes?
Hello Joseph
My assumption when you have a ABR running in between a NSSA, this ABR will perform the type 7-5 lsa translation and then flood those types 5 into its other areas, So surely this will then designate that ABR to be an ASBR for those other areas?
Kind Regards
Paul
No, not conceptionally.  Again, it's not the original router injecting external routes.
Also again, look at my prior referenced Cisco TechNote two diagrams where they only label a router as an ASBR if it's redistributing routes external to the OSFP domain.
Or, what my browser's AI describes:
ASBR stands for Autonomous System Boundary Router, which is a router that connects an OSPF network to other routing domains or protocols, allowing for the exchange of routing information. It plays a crucial role in importing and redistributing external routes into the OSPF network.
Paul, do you have any reference information that supports your assumption?
Lastly, a NSSA ABR could also be an ASBR, but not just for type 7 translation to type 5 coming from an ASBR within the NSSA.
Hello Joseph
Mainly just based my own studies and various labbing of the protocol.
We know flooding aspect a normal ASBR, will flood type 5 LSAs for external prefixes
So taking that one step further, An ABR of an NSSA will first translate type7-5s LSAs with their attached forward addresses (FAs) then will flood (not redistribute) those type 5 LSAs just as a normal ASBR will do, thus making it become an ASBR also?
When I get the time mate ill lab it up and share the results..
Kind Regards
Paul
Paul, you appear to be assuming that a type 5 LSA always corresponds to an ASBR, but it doesn't.
Perhaps this AI summary will help:
OSPF LSA 5 vs Translated
In OSPF, LSA Type 5 and translated LSA Type 5 serve the purpose of advertising external routes, but they operate in different contexts and have distinct characteristics.
LSA Type 5
  • Origin: LSA Type 5 is generated by an Autonomous System Border Router (ASBR) to advertise routes that are external to the OSPF domain.
  • Flooded To: These LSAs are flooded throughout the entire OSPF domain, except for stub areas.
  • Purpose: They are used to advertise external routes, such as those learned from BGP or static routes, into the OSPF network.
  • Example: An ASBR might redistribute a BGP route into OSPF, creating a Type 5 LSA for that route.
Translated LSA Type 5
  • Origin: Translated LSA Type 5 is generated by an Area Border Router (ABR) in a Not-So-Stubby Area (NSSA).
  • Flooded To: These LSAs are flooded from the NSSA into the backbone area and then throughout the OSPF domain.
  • Purpose: They are used to translate Type 7 LSAs, which are specific to NSSAs, into Type 5 LSAs so that external routes can be advertised to the rest of the OSPF domain.
  • Example: An ASBR in an NSSA generates a Type 7 LSA for an external route. The ABR in the NSSA then translates this Type 7 LSA into a Type 5 LSA and floods it into the backbone area.
Key Differences
  • Area of Origin:
    • Type 5 LSA: Originates from an ASBR and is flooded throughout the OSPF domain.
    • Translated Type 5 LSA: Originates from an ABR in an NSSA and is translated from a Type 7 LSA.
  • Area Restrictions:
    • Type 5 LSA: Not allowed in stub areas.
    • Translated Type 5 LSA: Allowed in all areas, including the backbone, after translation.
  • Purpose:
    • Type 5 LSA: Directly advertises external routes.
    • Translated Type 5 LSA: Facilitates the advertisement of external routes from an NSSA to the rest of the OSPF domain.
Why Translation is Needed
  • Memory and CPU Efficiency: Translating Type 7 LSAs to Type 5 LSAs helps minimize the memory and CPU usage of routers. In an NSSA, every ABR has two copies of every external route in its topology database: a Type 7 LSA in the NSSA area and a translated Type 5 LSA in the backbone area. The dedicated translator (the ABR with the highest router ID) handles the translation, which avoids unnecessary duplication and reduces overhead.
Summary
  • Type 5 LSA: Advertises external routes from an ASBR and is flooded throughout the OSPF domain.
  • Translated Type 5 LSA: Translates Type 7 LSAs from an NSSA into Type 5 LSAs, allowing external routes to be advertised to the rest of the OSPF domain.
This translation mechanism ensures that external routes can be effectively advertised while maintaining the efficiency and scalability of the OSPF network.
Hello
Not at all Joseph-  what i’m saying is in scenarios when an ABR of an ASBR is performing LSA translation and then type 5 flooding it is in retrospect also becomes ASBR.
Kind Regards
Paul
Well, you might be alone in that belief, because the ASR isn't actually doing the initial redistribution into the OSPF domain. Have you found anyone else saying the same?
It's sort of like also saying, every downstream router that continues to pass along the type 5 LSAs are also ASBRs (which I doubt you would).
Or consider it this way, when you reach the actual ASBR, your packet can now exit the OSPF domain and enter the external AS, for the route being advertised.  But, if a packet, with an external route, reaches the NSSA ABR, doing the translation, it cannot be immediately forwarded into the external AS, it still needs to be forwarded to the actual ASBR, which may be multiple NSSA area router hops away.
Or consider, within an area, all the routers use interior area routes to reach the ASBR, they don't go to the ABR (unless it's also the ASBR).
All the above aside, other than an ABR translating type 7 to type 5 LSAs, what's the conceptional reason or advantage "making it" an ASBR?
Again, if a packet wants to transit to the external route, it needs to reach the ASBR, which may, or may not, also transit an ABR.
Lastly, consider an OSPF router with two non-zero areas connected to it, but not area zero.  You do know, if, per chance, a packet from area X wants to reach area Y, and it transits the router with X and Y area interfaces, again without area zero, the packet can jump between the areas.  However, this doesn't make that router an ABR.
As an area zero connection and non area zero connection(s) is fundamental to being an ABR, doing external AS redistribution, not translation, appears to be fundamental to being an ASBR.
This has been a very interesting discussion. In thinking about it I believe that it may be helpful to focus on the "B" of ASBR. The ASBR is at a Boundary of OSPF and something else (which could be another dynamic protocol or might be static, or?). I am not clear what (if anything) we should designate for the router that translates type 7 to type 5. But I do not believe that it would be a Boundary.
Rick
I've just been perusing RFC 1587 (obsolete) and RFC 3101.
Those RFCs refers to such a router as "NSSA border router".  These are ABRs that support the (optional) NSSA.
BTW, came across this rather old community posting:
https://community.cisco.com/t5/routing/ospf-nssa-type-7-to-type-5-translation/td-p/1409611
Which addresses the same question, i.e. is the NSSA border router, doing (just) translation, also an ASBR.
Initially, in that thread, a NSSA border router is not considered an ASBR, until RFC 1587 is quoted.
However, if you peruse more of RFC 1587, I think the  RFC quote was just poorly worded, and isn't correct.
If you read the newer RFC 3101 section 2.4, the noted RFC 1587 wording has been removed (i.e.
All NSSA area border routers must also be AS boundary routers
) to further make clear the NSSA border router isn't an AS boundary router, unless, it's directly dealing with an AS boundary.  I.e. translation of type 7 to type 5, alone, doesn't make it an ASBR.
Interestingly, with a NSSA capable ASBR, it can generate either type 5 or type 7, depending on area type, but it's an ABR function to translate type 7 to type 5.
ABR and ASBR are distinct roles, and of course, both roles might be supported by one router, but it still seems to me, an NSSA border router only doing type 7 to type 5 translation, is not an ASBR.
BTW, what I suspect makes this issue/question somewhat confusing, the NSSA was added as an option to OSPF, and its design appears to attempt to minimize or capitalize on how OSPF already worked.  For example, we cannot have type 5 LSAs in the new NSSA, because they are using built on stub area rules, so we create a whole new LSA type, type 7, but once we get to the ABR, why not just "reuse" type 5 LSAs?  The rest of OSPF can continue to work as if the ASBR was actually generating the type 5 LSAs.  (In a way, we're doing "NAT" for LSA types rather than IP addresses.)  Only the NSSA ASBR and NSSA ABR, really need to "know" about type 7 LSAs and its additional rules, like what if the NSSA has multiple ABRs.
Hello Joesph
TBH external path selection can be and is sometimes to me ambiguous , Especially given all the various criteria that can be involved in say a NSSA path determination across single/dual ABRs -  same/differing FAs (quad /non quad 0s) , route-preference, cost, filtering and obviously the dreaded RFC compatibility
All the above can be gleaned by RFCs and online documentation and test books etc..and  I might be as you say be  on my own in this instance but when I do my own labs I know then with some degree of certainly what I am seeing actually is correct.
Please review the attach file,, it clearly shows that an ABR (RTR3) that is attached to a NSSA ASBR (RTR4), performing type7-5 translation and the OSPF DB is clearly stating that RTR3 ABR  is also an ASBR, the other RTRs (1&2) in the BB and non BB areas also see the same, with RTR2 also creating the type4 summary for RTR3
Kind Regards
Paul
Paul, as I did find that old forum posting, on the question of is an ABR doing the 7 to 5 translation an ASBR, you're not totally alone in the belief that it is.
One long standing statement that supports this belief, might be "If it walks like a duck and quacks like a duck, it's a duck."
I totally agree it sure looks like it's an ASBR duck.  (I don't believe I said otherwise and, hopefully, didn't imply otherwise, either.)
It may seem I'm asking:  "are you going to believe me or your darn lying eyes"?  If so, that's correct.
Unfortunately, my "red pill" writings, apparently were insufficiently potent for you to "see" that a NSSA ABR only doing 7 to 5 translation is also an ASBR is just a construct of the OSPF "matrix".
Perhaps the final take away might be, not only avoid discussions on religion or politics, but also avoid discussions of NSSA ABRs doing 7 to 5 translations being ASBRs.  ; )
Seriously though, a very interesting discussion, although possibly much more than @rookie R expected.
Joseph W. Doherty
#1 You would need to check each OSPF router for active redistribution into other routing protocols of interest or you would need to examine the contents of other routing protocols for the OSPF redistributed routes, although the latter can be hit or miss for various reasons.  Examination of just the route table is also very hit or miss, for various reasons.
#2 That router's OSPF "route table" for a specific OSPF router process.  (EDIT note, my prior statement implied the whole route table, which isn't the case.  But, you need to be aware there are scenarios where you can incorrectly redistribute routes already redistributed by another router.  BTW, this article and this article might be worth reading.  Neither directly addresses OP questions, but both, somewhat, touch upon some redistribution consideratios that get into my "various reasons", above.  Redistribution can easily become complex.)
#3 Ditto #1.
BTW, more complex redistribution scenarios (like multiple routers doing redistribution and/or mutual redistribution and/or using same links, in multiple routing protocols, concurrently) are an aspect of networking that's rather easy to get wrong and mess up a network.
