How to set a NAT on ipsec tunnel?
Imed
i setup an ipsec between a ciso router and a fortigate firewall.Tunnel is up in both device while the two LAN subnets are unable to ping each other.
i saw lot of articles and tuto and sounds confused about the necessity of NAT on cisco side!!!!!!
please let me know how far is the NAT important on IPSEC tunnel?
Here is the cisco config summary
Router(config)#do sh run
Building configuration...
Current configuration : 1437 bytes
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 10.10.20.2 10.10.20.20
ip dhcp pool my_lan
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
dns-server 8.8.8.8
ip cef
no ipv6 cef
crypto isakmp policy 10
hash md5
authentication pre-share
group 2
crypto isakmp key eve123 address 192.168.174.31
crypto ipsec transform-set fortigate esp-des esp-md5-hmac
mode tunnel
crypto ipsec profile phase2
set transform-set fortigate
set pfs group2
interface Tunnel10
ip unnumbered FastEthernet0/0
tunnel source 192.168.174.30
tunnel mode ipsec ipv4
tunnel destination 192.168.174.31
tunnel protection ipsec profile phase2
interface FastEthernet0/0
ip address 192.168.174.30 255.255.255.0
ip nat outside
duplex full
interface FastEthernet1/0
ip address 10.10.20.1 255.255.255.0
ip nat inside
duplex full
ip nat inside source list 99 interface FastEthernet0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.174.2
ip route 10.10.10.0 255.255.255.0 Tunnel10
access-list 99 permit 10.10.20.0 0.0.0.255
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
20 Replies 20
from the ping command
I am checking Tutos and it sounds thats problem of clocking or other config mismatch on Tunnel int,
line protocole on int tunnel goes up and down
I am not sure the 'ip unnumbered' works with the NAT outside interface. Try and assign a different IP address to both tunnel interfaces, such as this one:
interface Tunnel10
ip address 172.16.1.1 255.255.255.0 (--> 172.16.1.2 on the Forigate)
Imed
hello,
that didn't work
Imed
As you see guys on the capture there s no prob with the fortigate. i do not see any traffic comming from cisco.
I just tested your setup in a lab. What if you change the IPSec profile to:
--> set pfs group5
