10-10-2023
05:56 AM
- last edited on
10-13-2023
02:14 AM
by
Translator
Hi friends, I want to do the
c9200/9300 series (IOS 16.9.xx) VRRP (v2)
authentication, but I can't find it on the CLI. Can you please tell me? I beg you.
Solved! Go to Solution.
10-10-2023
11:17 AM
- last edited on
10-13-2023
02:17 AM
by
Translator
Not that i have seen any Authentication document or command found on the device i am using Cat 9300 with latest code
17.3.X or 17.6.X
only
vrrpv3
support most of new switches.
as i remember only i have used
vrrp v1
have authentication syntax i used for Routers to use VRRP.
10-10-2023
11:17 AM
- last edited on
10-13-2023
02:17 AM
by
Translator
17.3.X or 17.6.X
only
vrrpv3
vrrp v1
