how to set username and password on router
redindian
hi, i'm a newbie here, can any experts guide me on how to set a username and password on a router, for instance 2503 router, thank you in advance.
spremkumar
Level 9
Level 9
Are you trying to configure username and password for login purpose ?
if yes then do refer the below link for more info on the same...
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7a7.html
regds
mohammedmahmoud
Level 11
Level 11
You can do this in 3 fashions:
1. Just use VTY and enable passwords.
2. Use local usernames and passwords on the router.
3. Use AAA.
The first case is easy:
enable secret xxxx
line vty 0 4
login
password xxxxx
The second case:
username xxxx password xxxx
enable secret xxxx
line vty 0 4
login local
The third case, i think that Edwin has provided a nice document for it.
HTH,
Mohammed Mahmoud.
Pavel Bykov
Level 5
Level 5
I guess something like this could work:
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization commands 15 default local
username testuser secret testpassw
username testuser2 secret testpassw2
and so on.
hope this helps.
