How to setup Cisco 890 true webinterface
wesley
I have a Cisco 890 Router. But I lost the setup CD/DVD to configure my Cisco 890. Can somebody tell me
how I can access the webinterface or setup from this router. Or can I somewhere download the software?
Thx
81 Replies 81
hereby a drawing. The cisco router comes in a seperate building. So not option
to connect to do D-Link switch
Wesley,
try the configuration I provided, and see if you get it to work.
Thx,
I will try this and keep you posted
 witch commands do I use for the configuration
Kind Regards
it might be a better idea to save the configuration as a text (.txt) file and use an (T)FTP to copy it into the flash of your router...
Ok what program do you suggest to do the T FTP?
Solar Winds TFTP server is a good option, it is free:
http://www.solarwinds.com/free-tools/free-tftp-server
I also have a idea. I can give you access at teamviewer so you can access my router. Because this is al new for me and still learning and I dont want to fuck up this router :-)
Teamviewer...is that free for me to use ?
yes it is :-)
https://www.teamviewer.com/en/
OK. It will take me a bit, about 30 minutes, to log on. I am preparing dinner for my old father in law (no kidding)...;)
No problem give me a shout when you ready :-)
I added the configuration.
What would be helpful is to post a schematic drawing of your network, including all devices, connections, and how and with which device you are connecting to the Internet.
First of all thx for the help :-)
For moment we want to use the wireless on it
and there is coming a ps4 on it and a Amplifier that needs updates true internet
where in the password recovery process did you get stuck ?
