How to setup Cisco 890 true webinterface
wesley
I have a Cisco 890 Router. But I lost the setup CD/DVD to configure my Cisco 890. Can somebody tell me
how I can access the webinterface or setup from this router. Or can I somewhere download the software?
Thx
81 Replies 81
ID: 675 657 407
password: su8r58 or I30generation
in the configuration, I have used YOURSSID as ssid, you might want to change that, or use it as is for your clients.
So, ssid is the literal string 'YOURSSID'...
ok I change that later maybe when I know how to do it :D
Is it normal I can't find the wireless for the moment on my smartphone. Should display YOURSSID?
YOURSSID is the name configured, that should be what is being broadcast...
tested on my laptop also nothing happens. hmm strange
If you want to, I can log back on and check which SSID is being broadcast...
go ahead my pc is still on
I putted a networkcable in the interface ethernet0
I cannot login with cisco/cisco. I think that is because you have CCP active...can you login ?
can you do a password recovery as described in the document linked below:
http://www.cisco.com/c/en/us/support/docs/routers/800-series-routers/12065-pswdrec-827.html
I will do this tomorrow after work and contact you again. Thx for all the help
you already give me. It's quite alot to learn :-)
ok.
Cisco is definitely not the easiest device to set up...
I followed the steps but I'm stuck. Some off the commands don't work
you still want to help me?
I'm stuck at point 3 opf the last 6 points
point 3 as in:
Issue the no shutdown command on every interface that you use.
If you issue a show ip interface brief command, every interface that you want to use should display up up.
What doesn't work ?
