how to shut vty 5 15
abhishekm4u
how we can shutdown the vty 5 to 15 on a router or L3 switch. any command ??
For some platforms (for example the 3560 switches) you can't remove any of the 16 VTYs (0-15), as a work around you can disable these lines via "no exec".
BR,
Mohammed Mahmoud.
12 Replies 12
Goutam Sanyal
Level 4
Level 4
Hi Abhi,
The basic is use "no" to decline any command to a Cisco router.
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#line 5 15
No physical hardware support for line 5
Router(config)#no login
Thanks & Regards
Goutam
Pls rate if it works
mohammedmahmoud
Level 11
Level 11
Kindly use "no line vty 5 15".
[edit] Goutam, the login command is used to enable password checking, using "no login" tells the router not to enable password checking on this line and to grant anyone access on this line without a password check.
BR,
Mohammed Mahmoud.
hi ,
both commands not working
no line vty 5 15 shows below error and no login shows incomplete command.
kindly guide !
RJ-JPR-GUM-R1-64-6(config)#no line
RJ-JPR-GUM-R1-64-6(config)#no line vt
RJ-JPR-GUM-R1-64-6(config)#no line vty 5 15
% Can't delete last 16 VTY lines
RJ-JPR-GUM-R1-64-6(config)#line vt
RJ-JPR-GUM-R1-64-6(config)#line vty 5 15
RJ-JPR-GUM-R1-64(config-line)#no lo
RJ-JPR-GUM-R1-64(config-line)#no logi
RJ-JPR-GUM-R1-64(config-line)#no login
% Incomplete command.
HI
Can u try no line vty 4 15
Mahmood
BR,
Mohammed Mahmoud.
Hi Mahmood,
I have shutdown a telnet connection to a remote router, however on the remote shows that the connection is still active but idle. How to shutdown this connection?
Dear Jason,
following commands will be used:
  • show user
  • clear line <line number> / clear line vty <vty line number>
using capture above where we see output of command "show user" we see <line number> as 866, 867 and  <vty line number> as 0,1
so for same user to be disconnected command will be
clear line 867  or clear line vty 1
Router# conf t
Router(config)#no line vty 5 15
Router(config)#
Its work and no need to put the command "no login"
With ur out-put is showing that 1s u disable the line & after u enableing it again.
Router(config)#no line vty 5 ?
<6-15> Last Line number
Goutam
pls rate if it works
Yes. We can delete unnecessary line vty.
regards
skrao
Hi Mohammed,
Thanks to rectify me :-)
abhishekm4u
issue resovled by command no exec .
thanks mohd & gautam !!
Aydin Ehtibarov
following command can be used if line 5 15 cannot be deleted using command "no line vty 5 15"
   line vty 5 15
   transport input none
as the result when you will try to connect router will just close connection without negotiating any parameter
if you use commend
   line vty 5 15
   no exec
again access to router on those lines will not be possible but this time connection will be closed after ssh parameter negotiation
additional note: in both solution cases it will not prevent reverse telnet to aux port when lines 0 4 are busy .
