how to ssh in inter vlan
emmanuelalo209
hello how can i ssh in intervlan? when i do it the result is always connection timeout; remote host not responding. the example is attached
6 Replies 6
balaji.bandi
connection timeout; remote host not responding  - this means device not reachable or some config issue,
first ping the device before SSH, and SSH to device (check on the device logs what you see the error logs)
make sure all the devices configured SSH - example SSH config with username and password and VTY lines : use below quick fix for all SSH configuration all devices and test it : (cisco/cisco)
enable secret 5 $1$jtK0$yyHFcVM7xyelts1csVwrV/
username cisco privilege 15 secret 5 $1$0qFD$ZEMDi.7z1QTtF4EuPdlSY.
aaa new-model
aaa authorization config-commands
aaa session-id common
clock timezone GMT 0 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 2:00
no ip domain-lookup
ip domain-name bb.com
ip cef
no ipv6 cef
ip ssh version 2
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous level 0 limit 20
 stopbits 1
line aux 0
line vty 0 4
 privilege level 15
 password cisco
 transport input ssh
 transport output all
######### Generate SSH keys :
crypto key generate rsa
BB
hello good afternoon, how can i ssh when my pc is not on the same network as my switch  my pc ipv4 address is 192.168.10.10/24 my default gateway is 192.168.10 .1 my switch1 vlan address is vlan 99 - 192.168.99.10 my vlan 10 ip address is 192.168.10.0/24 when i try to ping the address of my switch (vlan99) the result is always request timeout same result when i try to ping the vlan 10  address in my sw1 , how can i fix this? sorry i'm just a beginner in cisco. I'm 2nd year college BS-information technology planning on majoring network technology that's why i trying to learn.
Hello
You need to fix the routing connectivity issue first before even trying to remote accessing those two switches, then as stated, ssh require to be enabled and allowed on those switches.
Share the PT file and maybe we can assist you obtaining that connectivity.
Kind Regards
Paul
hello, sorry for the very late reply i was bombarded with school acts. there's no PT file but i have the PKT file that i tried to do. I can't attached it here but do you want me to email it to you?
Now you need to troubleshoot and providing more information here :
what device model of this switch, and what code running ?
is this switch have default gateway ? ip routing enabled ?
provide below information :
show run
show ip interface brief
show vlan
BB
hello, sorry for the very late reply, i was bombarded with school acts can i email you the pkt file, it have basic configuration and ip on all vlans.
