12-04-2023 10:38 PM
How can i take GUI access of Cisco SG300 small business switch? I mean in which port i have to plug RJ45 cable, as of now I am able to ping 192.168.1.254 from my PC, if i put cable in any of port, but not able to access Gui.
Note- I do not have Serial-db9 console so the only way to take access is Gui.
Thnaks in advance!!!!
12-05-2023 12:42 AM
- What happens when you try to access the GUI on 192.168.1.254 ?
M.
12-05-2023 05:05 AM
Look at the quick start guide - the GUI should access from that IP as per the basic config.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/quick_start/78-19252-01.pdf
have you tried ssh to device ?
12-05-2023 07:27 AM
what IP address does your PC have ?
STEP 2 Set the IP configuration on your computer.
a. If the switch is using the factory default IP address of
192.168.1.254, you must chose an IP address for the computer
in the range of 192.168.1.1—192.168.1.253 that is not already in
use
if you still cannot access the 192.168.1.254 , it may be securtity settings on your browser
try both http://192.168.1.254 and https://192.168.1.254
if both fail you can try lowering the security setting in your browser, or try another browser
