Router not sending information from server network to other network in Packet Tracer - Please Help
Mirul
Good day,
Packet tracer is something new to me and this is my first task.
I cannot figure out why my DNS Server,FTP Server and Web Server only work with only 3 other Sys Admin Pc but not all other Pc in other network. My router seems to not pass data from the server network to other two network. Any idea how can i fix the issue?
I attached the pkt file for your reference.
Any help is greatly appreciated.
luis_cordova
Hi @Mirul ,
The problem is in the addresses adopted by the PCs of networks B and C, since they adopted the same range of addresses as network A.
To correct this, you must create a DHCP pool for each network and assign a prefix range that corresponds to your network:
After this, the PCs adopt the corresponding ip range and the ping is successful
I attached the corrected exercise
luis_cordova
Hi @Mirul ,
Hey @luis_cordova ,
Thanks for your time looking into the problem.
