How to track BGP session instead of "ip routing"?
tmikelson
As documented below when the "ip routing" goes down on interface Vlan20 the vrrp #1 decrements by 80 due to object tracking #3.  Now a problem has occurred where the BGP session for interface Vlan20 has gone down but "ip routing" staid up.  Any suggestions on how to track the BGP session instead of "ip routing" on interface Vlan20?
track 3 interface Vlan420 ip routing
interface TenGigabitEthernet1/2
 description REMOTE_CONNECTIONS
 switchport trunk allowed vlan 20,21,22
 switchport mode trunk
interface TenGigabitEthernet1/8
 description LOCAL_CONNECTION
 switchport access vlan 13
 switchport mode access
interface Vlan13
 ip address 10.13.1.2 255.255.255.0
 vrrp 1 ip 10.13.1.1
 vrrp 1 priority 120
 vrrp 1 track 3 decrement 80
interface Vlan20
 description COMMODITY
 ip address 10.20.1.3 255.255.255.252
interface Vlan21
 description INTERNET2
 ip address 10.21.1.3 255.255.255.252
interface Vlan22
 description PRIVATE_CONNECTION
 ip address 10.22.1.3 255.255.255.252
router bgp *****
 neighbor 10.20.1.2 description COMMODITY
 neighbor 10.21.1.2 description INTERNET2
 neighbor 10.22.1.2 description PRIVATE_CONNECTION
Vinit Jain
Hello
I dont really think you can do the tracking for BGP session directly using track object like you can do for ip routing but you can definitely configure a IP SLA probe to check reachability for the BGP peering IP and then integrate with track object.
Here is one good example of IP SLA with tracking object:
http://blog.codergenie.com/blog/post/2015/02/04/ip-sla-with-tracking.aspx
You can also configure an EEM script to perform certain actions when a BGP down notification is received, This way you may come to know if BGP session has gone down or stayed up.
Hope this helps
Vinit
--Vinit
