How to transfer files via X.25
baharin.hasan
Hi..
We are using HPUX server to collect files from switch to our server. Our server connect to cisco router and the cisco connect to X.25 protocol to communicate with switch. My question, how could i collect files from swicthes to our server and what is the command can i used ?.
This is some info about router.
'Serial0/0/0 is up, line protocol is up
   Hardware is GT96K Serial
   Description: LL018766
   MTU 1500 bytes, BW 1544 Kbit, DLY 10 usec,
   Encapsulation X25, loopback not set
   X.25 DTE, version 1984, address <none>, state R1, modulo 8, timer 0
       Defaults: idle VC timeout 0
         cisco encapsulation
         input/output window sizes 7/7, packet sizes 128/128
       Timers: T20 180, T21 200, T22 180, T23 180
       Channels: Incoming-only none, Two-way 2-16, Outgoing-only none
       RESTARTs 55/0 CALLs 0+0/0+0/0+0 DIAGs 0/0
   LAPB DTE, state CONNECT, modulo 8, k 3, N1 12056, N2 20
       T1 1600, T2 0, interface outage (partial T3) 0, T4 0
       VS 2, VR 2, tx NR 2, Remote VR 2, Retransmissions 0
       Queues: U/S frames 0, I frames 0, unack. 0, reTx 0
       IFRAMEs 57/4 RNRs 0/0 REJs 0/0 SABM/Es 214018/44 FRMRs 20/0 DISCs 0/0
   Last input never, output 1w2d, output hang never
   Last clearing of "show interface" counters 1w6d
   Queueing strategy: fifo
   Output queue: 0/40 (size/max)
Thank you
tony.henry_2
Try looking here.
I'm not sure you'll find exactly what your looking for but it'd be a starting point to ensure all your router infrastructure is working and able to transport the X25 stuff.
http://www.cisco.com/en/US/customer/tech/tk827/tk369/tk746/tsd_technology_support_sub-protocol_home.html
Tony
