Hi Marcus,
It is partially correct that IP Base will provide OSPF support. When I say "partially", it's because what the data sheet DOES NOT mention is that it's only OSPFv1 and not OSPFv2 or v3.
Go to Cisco Feature Navigator and verify if you can get OSPFv2/v3 to work on this switch.
I haven't tried it on this model but I'm guessing you need at least IP Services feature set.
