How to turn a standard BGP into a MP-BGP?
rookie R
Hi everyone!
As far as I know, the Multiprotocol BGP can support multiple address-family, while the standard BGP can only support ipv4 address. However, I am not sure how to determine if a BGP is standard that can only support ipv4 or MP-BGP that can support multiple address, and how to convert standard BGP to MP-BGP.
I know that the
no bgp default ipv4 unicast
 command can only turn off the default behavior that puts all the neighbors into the ipv4 unicast address family. It's not the switch to convert standard BGP into mp-bgp, so what is that switch to enable MP-BGP?
I searched on the internet and found a Juniper document that said:
Sorry, I couldn't find any Cisco document about this due to my poor ability, so I posted this Juniper document here.
So, is this the same in Cisco devices? Is it the same to assume that there is another address-family other than ipv4 unicast(for example, ipv6 unicast or ipv4 multicast), then it is MP-BGP? And If there is only ipv4 unicast in the configuration, then it's a standard BGP even if there is
command there?
R5(config)#do show run | s r b
router bgp 10005
bgp router-id 5.5.5.5
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 192.168.45.4 remote-as 10004
The above one is standard BGP, right?
R5(config-router-af)#do show run | s r b
router bgp 10005
address-family ipv6
exit-address-family
The second one is MP-BGP,right?
Thank you!
M02@rt37
Hello @rookie R
To enable MP-BGP, you need to introduce other address families beyond IPv4 unicast.
MP-BGP support multiple address families. The presence of other address families indicates the use of MP-BGP.
** MP-BGP is specified in RFC 2283.
http://www.ietf.org/rfc/rfc2283.txt?number=2283
Best regards
5 Replies 5
Blue_Bird
Hello rookie R,
  • MP-BGP is an extended BGP that allows BGP to carry routing information for multiple network layer protocols IPv6, VPNv4, and others. MP-BGP allows you to have a unicast routing topology different from a multicast routing topology, which helps to control the network and resources.
  • By default, commands entered under the
    router bgp
  • command apply to the IPv4 address family. This will continue to be the case unless you enter the
  • command as the first command under the
    router bgp
  • command. The
  •  command is configured on the router to disable the default behavior of the BGP routing process exchanging only IPv4 addressing information with BGP neighbor routers. Now, BGP routing process can exchange IPv4, IPv6 and VPNv4 addressing information with BGP neighbors.
  • Cisco IOS version 12.4T or Later versions supports MP-BGP
Reference: Encor official Cert Guide; https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/113555-mp-ebgp-config-00.html
Best regards
******* If This Helps, Please Rate *******
M02@rt37
Hello @rookie R
Best regards
Hello
You can use the
bgp upgrade-cli
command to convert BGP into the Address Family (AF) format or manually configure an AF  within the bgp process which will then change bgp to the AF format.
router bgp xx
bgp upgrade-cli
or
router bgp xx
address-family ipv4 unicast|multicast
address-family ipv4 vrf (vrf)
address-family ....etc
Kind Regards
Paul
I think all new IOS ver. is run MP-BGP
https://aurumme.com/atech/mp-bgp-address-families/
MHM
again all new IOS is run MP-BGP (extension of BGP-4)
so your original post is MP-BGP and you config IPv4 under it.
MHM
