how to tweak path when 1 tunnel has 2 nhs, using EIGRP
prabinchand
NOTE: Topology is attached below.
i am doing dmvpn from HUB to SPOKE2. hub-standby & hub-active has 1 tunnel each whereas SPOKE2 also has 1 tunnel but with 2 nhs [172.16.10.1/24 & 172.16.10.2/24] pointing towards HUB routers.
I have used EIGRP between HUB routers & SPOKE2.         Both HUB routers know path for 192.168.20.0/24 via tunnel-1 but from SPOKE2 router, it has 2 path to reach 192.168.10.0/24...
SPOKE2: D 192.168.10.0/24 [90/26882560] via 172.16.10.2, 00:02:08, Tunnel1
                                              [90/26882560] via 172.16.10.1, 00:02:08, Tunnel1
Now,
my main point is, SPOKE2 router must know the  path 192.168.10.0/24 via  tunnel1 [172.16.10.1] as primary path and [172.16.10.2] as secondary path.
BUT how to do it? by tuning EIGRP
SPOKE 2 ROUTE :
      1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C    1.1.1.0/24 is directly connected, FastEthernet0/0
L    1.1.1.4/32 is directly connected, FastEthernet0/0
      172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C   172.16.10.0/24 is directly connected, Tunnel1
L   172.16.10.3/32 is directly connected, Tunnel1
      192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C    192.168.20.0/24 is directly connected, FastEthernet0/1
L    192.168.20.1/32 is directly connected, FastEthernet0/1
HUB-ACTIVE ROUTE:
      S* 0.0.0.0/0 [1/0] via 192.168.10.3
L   1.1.1.1/32 is directly connected, FastEthernet0/0
L   172.16.10.1/32 is directly connected, Tunnel1
     192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C   192.168.10.0/24 is directly connected, FastEthernet0/1
L   192.168.10.1/32 is directly connected, FastEthernet0/1
D   192.168.20.0/24 [90/26882560] via 172.16.10.3, 00:03:01, Tunnel1
S   192.168.60.0/24 [1/0] via 1.1.1.3
HUB-STANDBY ROUTE:
L    1.1.1.2/32 is directly connected, FastEthernet0/0
L   172.16.10.2/32 is directly connected, Tunnel1
L   192.168.10.2/32 is directly connected, FastEthernet0/1
D   192.168.20.0/24 [90/26882560] via 172.16.10.3, 00:02:46, Tunnel1
CONFIGURATION:
HUB-ACTIVE:
redundancy
ip tcp synwait-time 5
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp key FORISP1 address 1.1.1.3
crypto ipsec transform-set ISP1SET esp-3des esp-md5-hmac
crypto map ISP1MAP 1 ipsec-isakmp
set peer 1.1.1.3
set transform-set ISP1SET
match address 100
interface Tunnel1
ip address 172.16.10.1 255.255.255.0
no ip redirects
ip nhrp map multicast dynamic
ip nhrp network-id 1
tunnel source FastEthernet0/0
tunnel mode gre multipoint
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.0
duplex auto
speed auto
standby 2 ip 1.1.1.5
standby 2 priority 110
standby 2 preempt
standby 2 name WAN-INT
crypto map ISP1MAP redundancy WAN-INT
interface FastEthernet0/1
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
standby 1 ip 192.168.10.5
standby 1 priority 110
standby 1 preempt
standby 1 name INLAN
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/1
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
network 172.16.10.0 0.0.0.255
network 192.168.10.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.10.3
ip route 192.168.60.0 255.255.255.0 1.1.1.3
access-list 100 permit ip 192.168.50.0 0.0.0.255 192.168.60.0 0.0.0.255
nls resp-timeout 1
cpd cr-id 1
no cdp log mismatch duplex
control-plane
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
gatekeeper
shutdown
HUB-STANDBY:
redundancy
encr 3des
hash md5
set peer 1.1.1.3
match address 100
interface Tunnel1
ip address 172.16.10.2 255.255.255.0
no ip redirects
ip address 1.1.1.2 255.255.255.0
duplex auto
speed auto
standby 2 preempt
ip address 192.168.10.2 255.255.255.0
duplex auto
speed auto
standby 1 preempt
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
SPOKE2:
redundancy
interface Tunnel1
ip address 172.16.10.3 255.255.255.0
no ip redirects
ip nhrp map 172.16.10.2 1.1.1.2
ip nhrp map 172.16.10.1 1.1.1.1
ip nhrp map multicast 1.1.1.2
ip nhrp map multicast 1.1.1.1
ip nhrp nhs 172.16.10.1
ip nhrp nhs 172.16.10.2
ip address 1.1.1.4 255.255.255.0
duplex auto
speed auto
ip address 192.168.20.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
network 192.168.20.0
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
2 Accepted Solutions
I guess what you want to achieve is NHS redundancy/failover ? You could use NHS clusters on the spoke:
ip nhrp nhs 172.16.10.1 priority 1 cluster 1
ip nhrp nhs 172.16.10.2 priority 2 cluster 1
ip nhrp nhs fallback 5
prabinchand
i installed ios version 15.2 , and now it worked..
Thank you so much sir,
7 Replies 7
HELLO SIR,
priority option is not showing. Now what should i do ?
note: Poc is attached below
Sir, please reply i need solution .
with your current configuration, what is the output of:
show dmvpn
Which devices and IOS versions are you using ?
HELLO SIR,
OUTPUT IS ATTACHED BELOW:
IOS VERSION :
SPOKE2#show version
Cisco IOS Software, 7200 Software (C7200-ADVIPSERVICESK9_LI-M), Version 15.0(1)M, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 30-Sep-09 07:48 by prod_rel_team
ROM: ROMMON Emulation Microcode
BOOTLDR: 7200 Software (C7200-ADVIPSERVICESK9_LI-M), Version 15.0(1)M, RELEASE SOFTWARE (fc2)
SPOKE2 uptime is 7 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19
System image file is "tftp://255.255.255.255/unknown"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE400) processor (revision A) with 491520K/32768K bytes of memory.
Processor board ID 4279256517
R7000 CPU at 150MHz, Implementation 39, Rev 2.1, 256KB L2 Cache
6 slot VXR midplane, Version 2.1
Last reset from power-on
PCI bus mb0_mb1 (Slots 0, 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb0_mb1 has a total of 800 bandwidth points.
The set of PA-2FE, PA-POS-2OC3, and I/O-2FE qualify for "half
bandwidth points" consideration, when full bandwidth point counting
results in oversubscription, under the condition that only one of the
two ports is used. With this adjustment, current configuration on bus
mb0_mb1 has a total of 400 bandwidth points.
This configuration is within the PCI bus capacity and is supported
under the above condition.
PCI bus mb2 (Slots 2, 4, 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points
This configuration is within the PCI bus capacity and is supported.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
4 FastEthernet interfaces
509K bytes of NVRAM.
8192K bytes of Flash internal SIMM (Sector size 256K).
prabinchand
thanks for the update, glad that you got it to work. The other option would have been two tunnels on the spoke.
hello sir,
but got new problem "Tunnel, retry limit exceed" when i advertise tunnel and LAN netwokr using EIGRP.
please help sir,
NOTE: error is attached below.
CONFIGURATION:
SPOKE2
interface Tunnel1
no ip redirects
no ip split-horizon eigrp 1
ip nhrp holdtime 10
ip nhrp nhs cluster 1 max-connections 1
interface Tunnel2
ip address 125.25.25.3 255.255.255.0
no ip redirects
ip nhrp map multicast 2.2.2.1
ip nhrp map multicast 2.2.2.2
ip nhrp map 125.25.25.1 2.2.2.1
ip nhrp map 125.25.25.2 2.2.2.2
ip nhrp network-id 2
ip nhrp nhs 125.25.25.1 priority 1 cluster 2
ip nhrp nhs 125.25.25.2 priority 2 cluster 2
ip nhrp nhs cluster 2 max-connections 1
delay 6000
tunnel source FastEthernet1/1
speed auto
duplex auto
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
ip address 2.2.2.4 255.255.255.0
speed auto
duplex auto
router eigrp 1
network 125.25.25.0 0.0.0.255
no ip http server
HUB-ACTIVE
encr 3des
hash md5
crypto isakmp key FORISP2 address 2.2.2.3
mode tunnel
crypto ipsec transform-set ISP2SET esp-3des esp-md5-hmac
mode tunnel
set peer 1.1.1.3
match address 100
crypto map ISP2MAP 2 ipsec-isakmp
set peer 2.2.2.3
set transform-set ISP2SET
match address 100
interface Tunnel1
no ip redirects
interface Tunnel2
ip address 125.25.25.1 255.255.255.0
no ip redirects
delay 60000
standby 2 preempt
speed auto
duplex auto
standby 1 preempt
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
description ***ISP-2-SECONDARY***
ip address 2.2.2.1 255.255.255.0
standby 3 ip 2.2.2.5
standby 3 priority 110
standby 3 preempt
standby 3 name wlan2
speed auto
duplex auto
crypto map ISP2MAP redundancy wlan2
router eigrp 1
no ip http server
ip route 192.168.60.0 255.255.255.0 2.2.2.3 10
HUB-STANDBY
encr 3des
hash md5
mode tunnel
mode tunnel
set peer 1.1.1.3
match address 100
set peer 2.2.2.3
match address 100
interface Tunnel1
no ip redirects
delay 7000
interface Tunnel2
ip address 125.25.25.2 255.255.255.0
no ip redirects
delay 8000
standby 2 preempt
speed auto
duplex auto
standby 1 preempt
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
ip address 2.2.2.2 255.255.255.0
standby 3 preempt
speed auto
duplex auto
router eigrp 1
no ip http server
