use per-tunnel QoS with port-channel interfaces
Noovi
Hi Guys,
I am using iWAN setup with pre configured  per-tunnel QoS with port-channel interfaces.
I came to know that i need to use below command to make per-tunnel QoS commands effective
platform qos port-channel-aggregate <port-channel number>
Can you please confirm to configure above command we need to first remove all tunnel interfaces,  port channels to make this command effective
e.g.
no interface tunnel1
interface TenGig0/0/1
no channel-group 1 mode active
no interface port-channel1
platform qos port-channel-aggregate 1
And then configure back tunnel1, interface TenGig0/0/1 and port channel 1 ??
I don't think so. Add the command (platform qos port-channel-aggregate)
and then post the output of:
show policy-map interface port-channel x
ashok_boin
Level 5
Level 5
There is no specific restriction like this but please do check this command related restrictions below (link ref also below).
QoS Modular QoS Command-Line Interface Configuration Guide, Cisco IOS XE Fuji 16.9.x - Aggregate EtherChannel Quality of Service [Cisco IOS XE 16] - Cisco
Unsupported Feature Combinations for Aggregate EtherChannel Quality of Service
The following combinations of tunnel-type interfaces with QoS are not supported:
  • Generic Routing Encapsulation (GRE) tunnels with queuing policy-maps applied, which egress via a port channel with aggregate queuing
  • Static virtual tunnel interface (SVTI) and dynamic virtual tunnel interface (DVTI ) with queuing QoS applied, which egress via a port channel with aggregate queuing
  • Sub-interface belongs to service group and sub-interface applied with service-policy cannot be configured on the same aggregate port-channel simultaneously
  • MPOL - policy applied on both aggregate port-channel main interface and port-channel sub-interface
Note
Tunnels without queuing QoS (described above) are supported, but are not recommended because hashing algorithms may overload a given physical interface without adequate diversity in IP addresses.
With best regards...
Ashok
