site to site vpn, pre shred key is missing
noob_route
My config is all right,
here's config:
SPOKE1:
FastEthernet0/0 1.1.1.4 YES NVRAM up up
FastEthernet0/1 192.168.30.1 YES manual up up
FastEthernet1/0 unassigned YES NVRAM administratively down down
FastEthernet1/1 2.2.2.4 YES NVRAM up up
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp policy 2
encr 3des
hash md5
crypto isakmp key FORISP1 address 1.1.1.5
crypto isakmp key FORISP2 address 2.2.2.5
crypto ipsec transform-set ISP1SET esp-3des esp-md5-hmac
crypto ipsec transform-set ISP2SET esp-3des esp-md5-hmac
crypto map ISP1MAP 1 ipsec-isakmp
set peer 1.1.1.5
set transform-set ISP1SET
match address 100
crypto map ISP2MAP 2 ipsec-isakmp
set peer 2.2.2.5
set transform-set ISP2SET
match address 100
crypto map ISP1MAP
crypto map ISP2MAP
HUB1 :
FastEthernet0/0 1.1.1.2 YES NVRAM up up
FastEthernet0/1 192.168.10.2 YES NVRAM up up
FastEthernet1/1 2.2.2.2 YES NVRAM up up
encr 3des
hash md5
encr 3des
hash md5
crypto isakmp key FORISP1 address 1.1.1.4
crypto isakmp key FORISP2 address 2.2.2.4
set peer 1.1.1.4
match address 100
set peer 2.2.2.4
match address 100
crypto map ISP1MAP
crypto map ISP2MAP
what is the problem exactly ? Post the full running configurations of both sides...
when i try to ping from  192.168.50.2/24 -to - 192.168.30.2/24 , its showing key missing message in CLI of HQ-Active router & SPOKE1 ROUTER also no ping replies received.
HQ-Active router -ERROR_MESSAGE:         *Dec 2 19:18:51.335: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Informational mod e failed with peer at 1.1.1.4
HQ-Active router -ERROR_MESSAGE:     *Dec 2 19:21:33.835: %CRYPTO-6-IKMP_NO_PRESHARED_KEY: Pre-shared key for remote peer at 1.1.1.2 is missing
HQ-ACTIVE router
redundancy
ip tcp synwait-time 5
encr 3des
hash md5
encr 3des
hash md5
set peer 1.1.1.4
match address 100
set peer 2.2.2.4
match address 100
interface FastEthernet0/0
description ***ISP-1-PRIMARY***
ip address 1.1.1.2 255.255.255.0
duplex auto
speed auto
standby 2 ip 1.1.1.5
standby 2 priority 110
standby 2 preempt
standby 2 name wlanisp1
crypto map ISP1MAP
interface FastEthernet0/1
description ***LAN-INTERFACE***
ip address 192.168.10.2 255.255.255.0
duplex auto
speed auto
standby 1 ip 192.168.10.5
standby 1 priority 110
standby 1 preempt
standby 1 name inlan
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/1
description ***ISP-2-SECONDARY***
ip address 2.2.2.2 255.255.255.0
duplex auto
speed auto
standby 3 ip 2.2.2.5
standby 3 priority 110
standby 3 preempt
standby 3 name wanisp2
crypto map ISP2MAP
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.30.0 255.255.255.0 1.1.1.4
ip route 192.168.30.0 255.255.255.0 2.2.2.4 10
ip route 192.168.50.0 255.255.255.0 192.168.10.4
access-list 100 permit ip 192.168.50.0 0.0.0.255 192.168.30.0 0.0.0.255
nls resp-timeout 1
cpd cr-id 1
no cdp log mismatch duplex
control-plane
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
gatekeeper
shutdown
HQ_STANDBY router
redundancy
encr 3des
hash md5
encr 3des
hash md5
set peer 1.1.1.4
match address 100
set peer 2.2.2.4
match address 100
ip address 1.1.1.1 255.255.255.0
duplex auto
speed auto
standby 2 preempt
standby 2 name wanisp1
crypto map ISP1MAP
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
standby 1 preempt
no ip address
shutdown
duplex auto
speed auto
ip address 2.2.2.1 255.255.255.0
duplex auto
speed auto
standby 3 preempt
crypto map ISP2MAP
no ip http server
ip route 192.168.10.0 255.255.255.0 1.1.1.4
ip route 192.168.10.0 255.255.255.0 2.2.2.4 10
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
SPOKE1
redundancy
encr 3des
hash md5
encr 3des
hash md5
set peer 1.1.1.5
match address 100
set peer 2.2.2.5
match address 100
ip address 1.1.1.4 255.255.255.0
duplex auto
speed auto
crypto map ISP1MAP
ip address 192.168.30.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip address 2.2.2.4 255.255.255.0
duplex auto
speed auto
crypto map ISP2MAP
no ip http server
ip route 0.0.0.0 0.0.0.0 1.1.1.5
ip route 0.0.0.0 0.0.0.0 2.2.2.5 10
access-list 100 permit ip 192.168.30.0 0.0.0.255 192.168.50.0 0.0.0.255
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
For the DMVPN the IPSec key should config as
password # address 0.0.0.0<- in Hub
password # address 0.0.0.0 <- in Spoke "to make Spoke to Spoke connect"
THANK YOU EVERYONE, I FOUND THE ANSWER .
i just mapped the crypto map with redudancy as i pointed the spoke to the VIP of HUB, therfore
command on interface : crypto map [mapname] redudency [standbyname]
