How to upgrade lincence from ip base to ip services on catalyst 3560G router to enable ipv6 unicast routing
Catalyst 3560G router has software mention as below, I am trying to enable ipv6 unicast routing on this router. To enable it router should have ip service licence.  Please suggest which licence version to use.
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 07:19 by yenanh
Image text-base: 0x00003000, data-base: 0x00EB0F14
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
TP_CISCO uptime is 5 minutes
System image file is "flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin"
cisco WS-C3560G-24TS (PowerPC405) processor (revision D0) with 118784K/12280K bytes of memory.
Processor board ID FOC1045Y31B
Last reset from power-on
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1A:2F:4D:E2:80
Motherboard assembly number     : 73-10215-04
Power supply part number        : 341-0098-02
Motherboard serial number       : FOC1045314A
Power supply serial number      : AZS104402V5
Model revision number           : D0
Motherboard revision number     : A0
Model number                    : WS-C3560G-24TS-S
System serial number            : FOC1045Y31B
Top Assembly Part Number        : 800-26851-01
Top Assembly Revision Number    : A0
Version ID                      : V03
CLEI Code Number                : CNMW200ARC
Hardware Board Revision Number  : 0x09
Switch   Ports  Model              SW Version              SW Image
*    1   28     WS-C3560G-24TS     12.2(25)SEE2            C3560-IPBASE-M
Leo Laohoo
Send an email to Cisco Licensing Team with your CCO login, the serial number of the chassis and describe what you are trying to accomplish.
