CDP over Frame Relay sub interface
HiTmAn47
Hello ,
Is CDP supported over Frame Relay sub interface
Joseph W. Doherty
I would have so no, but recently I discovered CDP will work across GRE tunnels if you explicitly enable it on the tunnel interface (even though it works by default on other interfaces). Possibly similar for FR interfaces.(?)
Hello
I would say yes - as On Demand Routing (ODR)  can be ran on FR sub P2P interfaces and that requires CDP
res
Paul
Kind Regards
Paul
