How to upload IOS in redundant RP scenarios.
ncnaveen_arasu
How to upload IOS in one RP, when we have redundant RP in place? what are the precautions we need to take before uploading an IOS in a single RP.
Leo Laohoo
Command:  copy tftp://[TFTP IP address]/filename.bin slavesup-bootdisk:
Hi Leo,
Thanks for the reply
Is it the only command we will use for uploading IOS to secondary RP.
Before using this command do we need to do something like shutting management IP etc.
Please confirm.
And do we need to give IP,Gateway,Mask etc. If yes waht should be that in live network. Please clarify
No need.  Just that simple command will allow you to transfer a file from the TFTP server to the redundant supervisor card.
