How to use output modifiers - pipe symbol
kevin.hu
Level 3
Level 3
I figure out how to use the pipe symbol to form "AND" operator, such as
show cdp nei
| ex Gig|VMware (exclude BOTH Gig AND VMware keywords).
However, does anyone know how to use the pipe or other symbol to form "OR" and "NOT" operators?
Thanks.
slmansfield
Level 4
Level 4
The output of CLI commands can be modified using regular expressions.  Here is a URL that describes how to use them.  http://www.cisco.com/en/US/docs/ios/12_0t/12_0t1/feature/guide/cliparse.html#wp6028
I took the output of
show ip interface brief
which listed a bunch of different interfaces on my 2800 router, including Loopback0 and Tunnel0 interfaces.
To test the "or" I used another pipe between the two terms that I want to "or", which in this case is Loopback or Tunnel.  After the "or" I only want to see the Tunnel interface, so I just include that from the output of the prior selection for Loopback or Tunnel.
router#sh ip int brief | include Loopback|Tunnel | include Tunnel
Tunnel0                    1.1.1.1     YES NVRAM  administratively down down
To use a "NOT" condition I just use the "exclude" after whatever selection I chose prior to the exclude.  In this case, I first chose Loopback or Tunnel.  From that output I excluded Tunnel so that I only have Loopback in my output.
router#sh ip int brief | include Loopback|Tunnel | exclude Tunnel
Loopback0                  2.2.2.2   YES NVRAM  up                    up
slmansfield
Level 4
Level 4
