How to verify optical power level in a SFP inserted in a cisco 3800
william.tituana
Hi all,
I have a Cisco3800 with IOS Version 12.3(14)T2 and I have an HWIC-1GE-SFP module inserted on it.
I need to know if there is a command to verify optical power level in this module inserted in the Cisco 3800 router?
Something similar to the following command that I can execute in an Cisco ASR9K:
show controllers Te0/0/0/1 phy | i Rx
Thanks in advance for your answers.
8 Replies 8
Ivan Shirshin
Hi William,
It is "show interfaces ... transceiver detail" command.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Hi Ivan,
Thanks for your answer but that command its not available for that interface.
paolo bevilacqua
That is DOM. It's only supported on certain modules, and likely not supported on the 3800 at all.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_8031.html
Paolo, you are right, DOM is not supported on this HWIC:
Minimum Software Release Required
Platform
Switch or Module
Transceiver Module
DOM Support
Cisco IOS Release
HWIC-1GE-SFP
GLC-T
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
CWDM SFP
GLC-SX-MMD
GLC-LH-SMD
12.3(8)T4
The card with DOM support is EHWIC-1GE-SFP-CU and it is supported on ISR-G2 only.
DOM support provides optical levels, including such commands as:
     show int transceiver detail
     show controller | incl Diag
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
santoshautade
I am facing this issue while I am using following comand on 3900 series router which comand should I Use to check optical power on this router ????
DLHIPDNGAMR001#sh interfaces Gi0/1/0 transceiver detail
Module 0 doesn't support DOM
DLHIPDNGAMR001#sh interfaces Gi0/0 transceiver detail
Hi William:
Try this
show hw-module subslot 0/0 transceiver 1 status
Thanks bro...
works well
On the Catalyst 9300 you can perform.
# show interfaces transceiver detail.
This command will show the temperature, voltage, current, decibel levels, and thresholds.
