ISR and license conversion status ?
DWAM
Hello all,
I've got 2 ISRs 4321 and 2 ISR 4331.
On 3 of them, I've got the follow output :
ISR1or2or3 #sh license all
Smart Licensing Status
Smart Licensing is ENABLED
License Conversion:
Automatic Conversion Enabled: False
Status: Successful on Oct 12 16:51:21 2021 GMT+1
On one of them, I've got the follow output :
ISR4#show license all
License Conversion:
Status: Waiting for response on Jan 01 02:00:00 1970 GMT+1
Next response check: Oct 14 16:50:29 2021 GMT+1
The second status is strange.
From the license dashboard, everything is OK.
Is it normal ?
Regards.
10 Replies 10
Leo Laohoo
What IOS-XE version are they running on?
hello LEO,
please find the version for all of them : "bootflash:isr4300-universalk9.17.03.03.SPA.bin"
New Deployment Method for Smart Licensing
Thank you for the links but it doesn't explain why the status of one ISR stays Waiting for response and the others are successfull. I don't know anyway if this message is important ?
Check the call-home config.
All with same configuration :
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
Wait ... the router 17.3.3 should no longer be participating in CSL.
Is it a false positive ?
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/csa/configuration/xe-3s/csa-xe-3s-book/csa-smrt-license.pdf
When you enable Smart Licensing,the Cisco Software License (CSL) and all licensing calls pass through the Smart Agent.
Read the link I have posted.  Starting from 17.3.2 CSL has a different "working model".
I've read the document but it doesn't explain why I have got 3 times the same result for ISR 1 2 3 and another result for ISR 4 with the same process ?
