Howto put token ring interface up?
piotrkrol
Level 3
Level 3
I have this Ethernet/Token Ring Router and would like to know howto put the interface TokenRing0/0 up?
ETHTR#sh version
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(5d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sat 02-Feb-02 03:36 by kellythw
Image text-base: 0x80008088, data-base: 0x80989870
ROM: System Bootstrap, Version 12.2(10r)1, RELEASE SOFTWARE (fc1)
ETHTR uptime is 7 hours, 3 minutes
System returned to ROM by reload
System image file is "flash:c2600-i-mz.122-5d.bin"
cisco 2612 (MPC860) processor (revision 0x00) with 28672K/4096K bytes of memory.
Processor board ID JAE071408W0 (2793660868)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Token Ring/IEEE 802.5 interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
ETHTR#sh interface TokenRing0/0
TokenRing0/0 is down, line protocol is down
  Hardware is HAWKEYE, address is 0030.a1a7.dd80 (bia 0030.a1a7.dd80)
  Internet address is 10.181.1.10/24
  MTU 4464 bytes, BW 16000 Kbit, DLY 630 usec,
  Encapsulation SNAP, loopback not set
  Keepalive set (10 sec)
  ARP type: SNAP, ARP Timeout 04:00:00
  Ring speed: 16 Mbps
  Duplex: half
  Mode: Classic token ring station
  Full duplex capable
  Group Address: 0x00000000, Functional Address: 0x08000000
  Ethernet Transit OUI: 0x000000
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue 0/40, 0 drops; input queue 0/75, 0 drops
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 327 interface resets
     0 transitions
ETHTR#sh run
ip address 10.181.1.10 255.255.255.0
ring-speed 16
ETHTR#show controllers tokenring 0/0
Interface TokenRing0/0 state: down
  Data from IDB:
    Current MAC address: 0030.a1a7.dd80, Burned in MAC address: 0030.a1a7.dd80
    Group address: 80000000
    Functional address: 08000000, enables: CDP
    Ring mode: 0000, enables:
    Device driver instance pointer: 80F936D8h
  Last Ring Status: none
    Stats: soft: 0/0, hard: 0/0, sig loss: 0/0
           tx beacon: 0/0, wire fault 0/0, recovery: 0/0
           only station: 0/0, remote removal: 0/0
  Interface failures: 0
  Current operating mode:
      MAC state: not inserted
  Internal controller data:
    MAC microcode version: 0.00
    Hawkeye ASIC revision: 3
    Node address: 0000.0000.0000
    Functional address: 00000000, Group address: 00000000
    Hawkeye ASIC registers:
      himr: 00000000h, inpace: 0000h
      utility: 7716h, txphthre: 10D0h, rxtxdmathre: 2828h
      dmactrl: 0000E01Ch, earlyrxthre: 0000h, llcstop: 0000h
      reset: 0002h
      txhidescstart: 00000000h, txlodescstart: 00000000h
      rxdescstart: 00000000h, srbctrl: 003Eh, descipoll: 3700h
      congestcnt: 0000h
    Hawkeye transmit error counts:
      Underrun: 0/0
    Hawkeye receive error counts:
      Out of descriptors: 0/0, Giants: 0/0
      Corrupted frames: 0/0, CRC errors: 0/0
      FIFO overflow: 0/0
    Device driver ring buffer data:
      Transmit ring:
        Ring size: 256 descriptors
        Descriptors outstanding: 0
        Head pointer: 0   Tail pointer: 0
      Receive ring:
        Ring size: 64 descriptors
        Head pointer: 0
    Internal controller soft error counts:
      Line errors: 0/0, Internal errors: 0/0
      Burst errors: 0/0, ARI/FCI errors: 0/0
      Abort errors: 0/0, Lost frame errors: 0/0
      Copy errors: 0/0, Receiver congestion: 0/0
      Token errors: 0/0, Frequency errors: 0/0
    Internal controller SMT state:
      Adapter MAC:     0000.0000.0000, Physical drop:       00000000
      NAUN address:    0000.0000.0000, NAUN drop:           00000000
      Last beacon src: 0000.0000.0000, Last poll:           0000.0000.0000
      Last MVID:       0000,           Last attn code:      0000
      Txmit priority:  0000,           Auth funct class:    0000
      Monitor error:   0000,           Front end errors:    0000
      Correlator:      0000,           Soft error timer:    0000
      Local ring:      0000,           Ring status:         0000
      Beacon rcv type: 0000,           Beacon txmit type:   0000
      Last beacon type:0000,           Bcn station NAUN:    0000.0000.0000
      Beacon drop:     00000000,       Phantom support:     0000
      Access prot req: 0000,           Access prot resp:    0000
      Policy flags:    0000,           Protocol event state:0000
      Ctrl ring state: 0000,           Protocol join state: 0000
      Reserved:        0000,           Protocol mon state:  0000
8 Replies 8
vmiller
Level 11
Level 11
Ah days of myu misspent youth!
you need a hub or switch plugged into the token ring port. then a no shut command would do it.
Thx, but the token ring hub is already connected to the token ring port from cisco router.
What's clue?
what are you plugging the router into? a true hub or a a T/R swtich ?
http://www.cisco.com/en/US/partner/products/hw/modules/ps2643/products_tech_note09186a0080093dc2.shtml
It's a Token Ring Hub.
Btw if I try to open this link that you posted, I get this message:
Forbidden File or Application
probably contract related, thats why i can see it and you can't.
If you are using just a passive MAU, you will need another station on there if memory serves me correctly.
you have just one station so a ring is not really being established.
Just curious, why are you doing this? T/R has been dead and buried for years.
I don't use MAU, we're using just RJ45 connectors at all our TR interfaces.
I need some data of a very old machine with TR interface.
BTW now it works.
"no shutdown" command on C2600 has solved this problem.
occams razor,  I should have asked if the interface was configured up.
After "no shutdown" TR interface comes up:
TokenRing0/0 is up, line protocol is up
  Keepalive set (30 sec)
  Ring speed: 16 Mbps
  Duplex: half
  Full duplex capable
  Last Ring Status 05:32:09 (0x2000)
  Last input 00:00:11, output 00:00:09, output hang never
     1788 packets input, 132432 bytes, 0 no buffer
     Received 421 broadcasts, 0 runts, 0 giants, 0 throttles
     3076 packets output, 261278 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
     1 transitions
