HSRP addresses in different subnets
carl_townshend
Hi all
I have 2 internet routers on site by a ISP, I have noticed that the main interfaces on both routers are in the same subnet, as per normal, and there is a group with a virtual address in this subnet as I would expect. However there is another group configured on the same interface where the standby IP address is not in the same subnet as the real address! , Will this really work?
Many thanks
Carl
You may use sub interface to achieve the same result... as thre are couple of limitations while particip
ating in dynamic routing protocol like OSPF.
If you are not planning to use OSPF in near future then you can continue with the configuration currently available...
Cheers!
6 Replies 6
Laurent Aubert
HI,
Please post the config
Laurent.
Basically one ip is 194.73.x.x and the other 194.74.x.x but the masks are /28
cheers
#sh standby
FastEthernet0 - Group 1
  State is Active
    37 state changes, last state change 4w1d
  Virtual IP address is 194.73.x.x
  Active virtual MAC address is 0000.0c07.xxxx
    Local virtual MAC address is 0000.0c07.xxxx (default)
  Hello time 3 sec, hold time 8 sec
    Next hello sent in 1.868 secs
  Authentication text "xxxx"
  Preemption enabled
  Active router is local
  Standby router is 194.74.x.x, priority 100 (expires in 7.868 sec)
  Priority 150 (configured 150)
    Track interface Serial0:0.1 state Up decrement 100
  IP redundancy name is "xxx" (default) FastEthernet0 - Group 2
  State is Standby
    59 state changes, last state change 3w1d
  Virtual IP address is 194.74.x.x
    Next hello sent in 0.488 secs
  Preemption enabled
  Active router is 194.74.x.x, priority 150 (expires in 6.484 sec)
  Standby router is local
  Priority 100 (default 100)
  IP redundancy name is "xxx" (default) xxxx-Pri#
FAILOVER
xxxx#sh ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              194.74.x.x    YES NVRAM  up                    up
Serial0:0                  unassigned      YES NVRAM  up                    up
Serial0:0.1                x.x.x.x     YES NVRAM  up                    up
#sh standby
  State is Standby
    42 state changes, last state change 4w1d
    Next hello sent in 0.620 secs
  Preemption enabled
  Active router is 194.73.x.x, priority 150 (expires in 7.628 sec)
  IP redundancy name is "xxxx" (default) FastEthernet0 - Group 2
  State is Active
    60 state changes, last state change 3w1d
    Next hello sent in 0.612 secs
  Preemption enabled
  Standby router is 194.73.x.x, priority 100 (expires in 6.688 sec)
I believe you are having two subnets
1.  Subnet A - 194.73.x.x - Active router is A and standby is B
2.Subnet B - 194.74.x.x - Active router is B and standby is A
Should work from the HSRP output pasted..
With regards,
Shailesh Hardas
You have two HSRP groups configured one for each subnet so you should have secondary addresses configured on your interfaces.
Is it working as expected ?
Laurent.
hi
yes it seems to be...so they must have secondary addresses on there??
i gather these dont show in ip int bri command??
cheers
Carl
Cheers!
