HSRP and GLBP on the same interface
pevorley
As anyone ever configured HSRP and GLBP on the same interface please?
If so, are there any things I need to watch out for please?
Thanks.
2 Accepted Solutions
Friend,
I did some test and there is absolutely no problem in defining HSRP and GLBP on the same interface.
have a look at the below config
interface FastEthernet0/0
ip address 10.10.10.2 255.255.255.0
duplex auto
speed auto
glbp 1 ip 10.10.10.100
glbp 1 priority 200
glbp 1 preempt
standby 1 ip 10.10.10.1
standby 1 priority 105
standby 1 preempt
The only problem is that you cannot have the HSRP virtual IP and the GLBP IP as same.
When you try to do that you get an error as mentioned below
R2(config-if)#glbp 1 ip 10.10.10.1
% 10.10.10.1 is assigned to another application on FastEthernet0/0
So in effect, if you want to run GLBP, then your hosts should point to the GLBP IP and if you want to run HSRP point to the HSRP virtual IP
HTH, rate if it does
Narayan
6 Replies 6
Thanks for the very quick reply. Unfortunately the other thread doesn't answer the question definitively. They think it will work (I think it will as well), but are not 100% sure.
The configuration guide doesn't state that enabling HSRP/GLBP will disable the other, but it also doesn't explicitly state that it doesn't either.
Please refer this doc...
http://ciscostudy.blogspot.com/2006_02_14_archive.html
Imran.
Friend,
duplex auto
speed auto
glbp 1 priority 200
glbp 1 preempt
standby 1 preempt
Narayan
Hi Narayan,
Thanks for much for trying this out for me, I really appreciate that.
This is exactly what I was after, so thanks again!!!
perfect, that's exactly what I was looking for. Thanks for taking the time to reply.
