HSRP and tracking
Amos Kafwembe
hello all.
I have dual ISP's comming into my network on two different routers. i have configured HSRP on my gateway router to failover if any of the tracked interfaces go down. How ever, there are instances where we lose internet connectivity upstream (not that the interface has failed or gone down) and in these cases the failover doesn't work.
is it possible to track eg, pings to google, such that, should pings fail HSRP should failover?
12 Replies 12
Dear Amos,
Can you post the config removing sensitive areas and have you included tracking interfaces in your config
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
cadet alain
http://mellowd.co.uk/ccie/?p=827
Regards.
Alain
hi.
i tried to do this config but my router doesnt have the "monitor" option.
take a look below.
(config)#ip sla ?
  key-chain  Use MD5 Authentication for IP SLAs Control Messages
  responder  Enable IP SLAs Responder
  server     IPPM server configuration
what should i do....??
Many thanks, It works for me.
what version of IOS are you using? is it the same as the one in the "show vwersion" i pasted earlier?
patrick.preuss
Can you please provide a Show Version. Ip sla has changed over Time. Old Versions May know rtr and track as commands.
Patrick
gateway#sh ver
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.1(4)M3, REL
EASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Dec-11 19:44 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
FIBER_rtr_gateway uptime is 4 days, 20 hours, 25 minutes
System returned to ROM by reload at 11:52:30 UTC Wed Nov 28 2012
System restarted at 11:53:57 UTC Wed Nov 28 2012
System image file is "flash0:c3900-universalk9-mz.SPA.151-4.M3.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE150/K9 with 987136K/61440K
bytes of memory.
Processor board ID FGL161412M3
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C3900-SPE150/K9       FOC16082HFZ
Technology Package License Information for Module:'c3900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            None          None           None
data          None          None           None
IP Base licnece has only IP SLA responder feature.
You need any of the UC, Data or Security licence to configure IP SLA probes
http://www.cisco.com/en/US/prod/collateral/modules/ps10598/ordering_guide_c07_557736.html
Raju
hi Raju.
thanks for the response. I will try to download the security image from the cisco site and test it.
patrick.preuss
It is an Universal Image . It is suffizient to add the Lic.
I dont understand what you mean....
