HSRP CONFIGURATION ERROR
brijendrasaini
DEAR TEAM,
WHEN I CONFIGURE HSRP EVERYTHING IS OK BUT WHEN I CONNECT R1 TO R2 AND R1 TO SWITCH2 THEN COMMINICATION STOP.
WHEN I REMOVE BOTH THE LINK THEN AGAIN EVERY THING IS OK
PASSWORD PACKET TRACER IS cisco when asked
hsrp ip 172.16.32.3 group number 10
please do needul so that i am able to confiure the same with both link.
 Please rename the file hsrp.pkt
Brijendra
Predrag Jovic
Level 3
Level 3
Now if you don't configure the priority, both devices will be working as active
Not really, if priority on all devices is the same (for example default 100) devices will use IP addresses as a tie breaker, device with highest IP address will become active router, other devices become standby routers.
Typically, split brain situation, where both devices act as active routers is when routers do not receive hrsp hellos from its neighbors.
In the first configuration (hsrp.pkt) there problem is/was
R1
interface Vlan50
 mac-address 00d0.ff33.8a01
 ip address 172.16.32.2 255.255.0.0
 standby 10 ip 172.16.32.1
R2
interface Vlan50
mac-address 0001.43ca.8601
ip address 172.16.32.1 255.255.0.0
standby 10 ip 172.16.32.3
Different standby IP addresses configured for the same HSRP group, and standby address on one of ther devices is the same as interface address on other device.
In lab hsrp.pkt I am getting warning about native VLAN mismatch. Native VLAN mismatch can lead to network loops. Please resolve that issue in your lab.
9 Replies 9
Julio E. Moisa
Can you paste the configuration on a notepad? Im not able to ready the file.
Thank you
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
r1
Switch>en
Switch>enable
Password:
Password:
Switch#show run
Building configuration...
Current configuration : 1511 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname Switch
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 50
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan50
standby version 2
ip classless
ip flow-export version 9
line con 0
exec-timeout 0 20
password 7 0822455D0A16
logging synchronous
line aux 0
line vty 0 4
login
end
r2
Current configuration : 1324 bytes
version 12.2
hostname Switch
interface Vlan1
no ip address
shutdown
interface Vlan50
standby version 2
ip classless
line con 0
line aux 0
line vty 0 4
login
end
I assume the switches are interconnected through an uplink and the ports assigned to the vlan 50.
Now I see the following on the DHCP configuration, it should be:
interface Vlan50
standby version 2
standby 10 preempt
standby 10 priority 105
interface Vlan50
standby version 2
standby 10 preempt
By default the HSRP priority is 100, a higher priority is always preferred to be the active device and the other device will be the standby. Now if you don't configure the priority, both devices will be working as active, you can see that through: show standby vlan 50.
So you need to assign a device as active to enable the redundancy. If the device active fails, the standby will take the active role, now imagine the previous active device is up again, the preempt command will be in charge to remove the active status to the current device and assign the role back to the primary device (the previous active)
Hope it is useful
hi julio,
What happen actual when i connect the switch from another switch and from router r1 to switch 2 then whole network jam.
That i ment to say in packet tracer all port link blink immediatlety.
I do not congifure switch direct connect without any configuration.
Dear Julio,
This is the structure when i connect the switch that start network jam or might be loop.
Predrag Jovic
Level 3
Level 3
R1
interface Vlan50
R2
interface Vlan50
Dear Predrag,
issue in vlan,as i correct it all things are working fine thanks a lot.
Brij
I am glad to hear it. You're welcome.
