HSRP Configuration
jorogan
Good Day,
I want to know if HSRP/VRRP/GLBP Configuration is supported in ISR4k switch?
if yes, may I know the requirements of configuring it. Thanks
for example:
Do i need 2 ISP connection?
Do i need to direct connection on both router?
Thanks for the help
jalejand
Hi Jorogan
HSRP, VRRP and GLBP are available options on a ISR4k router:
Router(config)#int gi0/0/0
Router(config-if)#standby 1 ?
authentication Authentication
follow Name of HSRP group to follow
ip Enable HSRP IPv4 and set the virtual IP address
ipv6 Enable HSRP IPv6
mac-address Virtual MAC address
name Redundancy name string
preempt Overthrow lower priority Active routers
priority Priority level
timers Hello and hold timers
track Priority tracking
Router(config-if)#vrrp 1 ?
authentication Authentication string
description Group specific description
ip Enable Virtual Router Redundancy Protocol (VRRP) for IP
name Register unique name with VRRS
preempt Enable preemption of lower priority Master
priority Priority of this VRRP group
shutdown Disable VRRP Configuration
timers Set the VRRP timers
track Event Tracking
Router(config-if)#glbp 1 ?
authentication Authentication method
forwarder Forwarder configuration
ip Enable group and set virtual IP address
ipv6 Enable group for IPv6 and set the virtual IPv6 address
load-balancing Load balancing method
preempt Overthrow lower priority designated routers
timers Adjust GLBP timers
weighting Gateway weighting and tracking
You don't really need a dual ISP connection, as FHRPs are meant to be redundancy tools applied to LANs, of course, these can be combined along tracking actions with dual ISP connections, although FHRPs do not strictly require ISPs to work in the first place.
No direct connection is needed, HSRP, VRRP and GLBP work through well known multicast addresses flooded through a broadcast domain, a switch in between the routers is good enough to provide Layer 2 connectivity between them, they have to be in the same subnet for HSRP/VRRP/GLBP operation.
To configure HSRP you can use the following guide/example:
https://community.cisco.com/t5/networking-documents/hsrp-overview-and-basic-configuration/ta-p/3131590
jalejand
Hi Jorogan
jorogan
Thanks for the answer,
follow up question, Do i need the router have a identical configuration? Thanks
only the parts relating to HSRP, VRRP and GLBP need to be 'identical', that is, they need to 'match' to work together, which in most cases means they are not 100% identical, e.g.:
R1
interface GigabitEthernet0/0
standby 1 ip 192.168.1.3
standby 1 priority 110
standby 1 preempt
R2
ip address 192.168.1.2 255.255.255.0
If you are talking about the HRSP then there will only two Identical Configuration on each router (One mandatory), try to understand an example:
R1 Configuration:
Interface FastEthernet 0/1
no shut
Ip address 192.168.1.1 255.255.255.0    -->Basic Rule, IP address must be Identical in the network (Identical)
standby 1 ip 192.168.1.254   --->                 this is a Virtual IP address. It must be the same in an HSRP group.
standby 1 priority 150 -----> If you want to make a specific router as Active router. (may Identical in a group)
standby 1 preempt
standby 1 authentication HSRP@TEST
R2 Configuration
no shut
Ip address 192.168.1.2 255.255.255.0    -->Basic Rule, IP address must be Identical in the network (Identical)
standby 1 preempt
If you are looking at the R2 Router configuration, I didn't configure "standby 1 priority xx" command because I want to use HSRP default priority(100).
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
