HSRP CORE & Internet load balancing
Kangalala
Hi guys,
I have configured hsrp for my Core Vlans and its working fine but I would like to load balance my internet Links as well according to source vlans with destination ISP. I have vlans 2 & 4 with Core1 priority so they will be able to use the 2 ISP links on the left, I also have vlan 3 & 5 using Core2 as priority so they will use the 2 ISP on the left. How can I destribuite traffic coming from certain vlan to use a specific ISP?
I have 2 default gateways for my Core switches: Core 1 im pointing to router hsrp address of one of the vlans of left side.
        Core 2 im pointing to router hsrp address of one of the vlans of right side.
so I have all traffic from left side going out of one ISP and same on the right side.
Topology attached.
2 Accepted Solutions
Francesco Molino
I'm not sure I get your concern.
if you want to route based on source IP, you need to use PBR.
to use you need to an acl (let's assume your lan 1 is 192.168.10.0/24 and lan2 is 192.168.100.0/24. Next hop for Lan1 is 10.100.10.1 and for Lan2 is 10.110.10.1)
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 permit ip 192.168.100.0 0.0.0.255 any
route-map LAN1 permit 10
 match ip address 100
 set ip next-hop 10.100.10.1
route-map LAN2 permit 10
 match ip address 101
 set ip next-hop 10.110.10.1
Int vlan1
 ip policy route-map LAN1
Int vlan2
ip policy route-map LAN2
PS: Please don't forget to rate and mark as correct answer if this solved your issue
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
No on the hosts side they should keep their default gateway as before.
Francesco
7 Replies 7
Francesco Molino
Int vlan1
Int vlan2
Francesco
thanks for your reply, and I would like to know if I remove my default gateway with this PBR applied to my vlans?
Francesco
My Lab is working fine with the route-map applied but to make it complete is there a way i can track the default route on the route-map applied so that i can switch to another gateway if the destanation becomes unreachable?
Nice to hear that.
Yes you can do taking on PBR. I won't cooy all commands here, just a Cisco link that explains how to do it:
http://www.cisco.com/c/en/us/support/docs/ip/ip-routed-protocols/48003-pbrtracking.html
Francesco
Hi, Just want to let you know that I am able to route individual vlans to different default gateways. One question I would like to know, does my configuration of set ip next-hop x.x.x.x address need to be a direct next hop or cant it be 2 or 4 hops away? I have OSPF running in all my equipments so all routes are available on the routing table.
Usually the next-hop is close in order to control traffic where we want to forward it. If you want to control traffic you can set next-hop 2 hops away but not sure that it will take the path you want.
You can also use PBR next-hop recursive if you want to control traffic path.
Francesco
