Hsrp help
mohammed.ullah
I am trying to setup two 4503 switches with HSRP and 10 vlans (5 on each switch).
Can you please help me out how to configure this thing up.
8 Replies 8
devang_etcom
Level 7
Level 7
VLAN: http://www.cisco.com/univercd/cc/td/doc//product/lan/cat4000/12_2_31s/conf/vlans.htm
HSRP: http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800b3e13.html
you will find how to confiugre HSRP and VLAN on given links...
hope this will help you
rate this post if it helps
regards
Devang
vladrac-ccna
Level 5
Level 5
Hello Mohammed,
To do HSRP on this 2 switches, you could use a trunk between the switches, some interfaces vlans and you hsrp on these vlans:
sw1:
conf t
vlan 2
vlan 3
vlan 4
vlan 5
vlan 6
int vlan 2
ip address 10.10.2.1 255.255.255.0
standby ip 10.10.2.66
standby priority 200
standby preempt
int vlan 3
ip address 10.10.3.1 255.255.255.0
standby ip 10.10.3.66
standby preempt
int vlan 4
ip address 10.10.4.1 255.255.255.0
standby ip 10.10.4.66
standby preempt
int vlan 5
ip address 10.10.5.1 255.255.255.0
standby ip 10.10.5.66
standby preempt
int vlan 6
ip address 10.10.6.1 255.255.255.0
standby ip 10.10.6.66
standby preempt
int fa0/23
switchport
switchport trunk encap dot1q
switchport mode trunk
int fa0/1
switchport
switchport mode access
switchport access vlan 2
int fa0/2
switchport
switchport access vlan 3
ON SWITCH 2, you would do the same:
vlan 2
vlan 3
vlan 4
vlan 5
vlan 6
int vlan 2
ip address 10.10.2.2 255.255.255.0
standby preempt
int vlan 3
ip address 10.10.3.2 255.255.255.0
standby preempt
int vlan 4
ip address 10.10.4.2 255.255.255.0
standby preempt
int vlan 5
ip address 10.10.5.2 255.255.255.0
standby preempt
int vlan 6
ip address 10.10.6.2 255.255.255.0
standby preempt
int fa0/23
switchport
int fa0/1
switchport
int fa0/2
switchport
I hope this help,
if this is not enough , give us more information about your requirements and I'd be glad to help.
Please rate all helpful posts.
Vlad
Hello All.
Do i have to make any changes on my router which is connected to these switches?
Any help will be appreciated.
Thank you Vlad.
no you donot need to make any changes on your router ...all this confiugration is on your switch only...
regards
Devang
you will have to make changes on your router if you need it to support forwarding of traffic from multiple VLANs.
if your router interface connected to the switch does not have to forward traffic to multiple VLANs, then you do not need to configure the router.
see this link for more info on configuring router for 802.1Q:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca804.html
Hello all.
I believe there are specific failover commands that can be implemented on switches.
my switches doesn't have to connected with router.
hello gpulos/all
Any body know,
I would also like to know what i have on any other redundancy configuration i can implement on two 4500 switches. (Other then HSRP).
Any help greatly appreciated.
mohammed.ullah
Hello all.
first of all sorry to bother you guys.
I need to know other then HSRP. Can i implement any other command to put Redundancy.
Like on two 6500 we can put some kind of failover command, but here is the case i have two 4500 switches.
Thanks for your help.
