HSRP in single router
harisivaji
Can we configure HSRP in single router connected to Two l2 switches thro FA port.
I need to monitor These two FA ports if one goes down another should come up and vice versa.
9 Replies 9
ohassairi
Level 5
Level 5
why do you need this?
Just for lab purpose
AJAZ NAWAZ
Level 5
Level 5
HSRP on single router chassis is not possible. However, there are various other potential solutions to this topology.
So which router platform do you have please?
Ajaz
Hi Ajaz,
I have 2611XM and two 2950 switch
paul.matthews
Level 5
Level 5
You can configure HSRP on a single router, but there's not a lot of point. The only point is if there are definite plans for a second router, and the single router is an interim solution.
You mention two switches - I am gonna take a wild guess and ask if you have two switches connected togther and you have two LAN interfaces on your router and want to cover for a failed LAN interface on either the router or switch? If so look at IRB - create a BVI, add the IP config to that and then just bridge the two LANs to the BVI.
The other alternative I can think of is the two switches are "upstream" in which case you would be better off with a routing protocol, or a poor second of floating static routes.
If I have guessed wrongly, please let us know what you are actually trying to do.
Hi paul ,
Is there any configuration document for the scenario.
Hari
Which particular scenario? I mentioned two...
I need for first one ie,IRB using BVI.
Why not using STP instead?!
