HSRP in switches with Multiple VLANs
ATHISESAN R
I'm currently working on creating a Redundancy in two different VLANs (100& 200) having a different network. Within the two switches (IOS2-1 & IOS2-2), I configure the default gateway for access switches in HSRP VIPs, But I still can't ping VLAN 100 to VLAN 200 through access switches for IOS2-3 & IOS2-4.
any one cloud help us to resolve this?
configuration
iosvl2-1:-
int vlan 100
standby 1 ip 100.1.1.254
standby 1 priority 105
standby 1 preempt
standby 1 authentication HSRP1
int vlan 200
standby 2 ip 200.1.1.254
standby 2 priority 100
standby 2 preempt
standby 2 authentication HSRP2
iosvl2-2:-
int vlan 100
standby 1 priority 100
standby 1 preempt
int vlan 200
standby 2 priority 105
standby 2 preempt
iosvl2-3:-
int vlan 100
ip add 100.1.1.3 /24
ip dedault-gateway 100.1.1.254
iosvl2-4:-
int vlan 200
ip add 200.1.1.3 /24
ip dedault-gateway 200.1.1.254
*enabled RSTP for all switches.
@need to ping both way int-vlans 100& 200 for iosvl2-3 <--> iosvl2-4
balaji.bandi
you have given the information you have configured HSRP. but you have not provided the below information to know better.
Do you have Routing enabled in 2-1 and 2-2 switches? what is connection config between 2-1 to 2-2 ? is this trunk?
how is your connection between 2-3 to 2-1 and 2-2 same 2-4 to 2-1 and 2-2, if the spanning tree kicking, one of the port will be blocking here.
so post all the device full config to understand and spanning tree output.
BB
