hsrp isolate
opnineopnine
Hi all,
I have an hsrp isolate in my nexus and I need to know if its working or not, how can i test this?
thanks.
9 Replies 9
InayathUlla Sharieff
Please check this:-
https://supportforums.cisco.com/discussion/11802396/dci-vpc-problem-hsrp-isolation-between-n5k-and-n7k
hello,
Thanks for the link but I dont see any troubleshoot it or test it.
thanks.
Hello
I have never performed any FHRP on nexus so my commnets would be associated with troubleshooting IOS FRHP.'s
1) are the peers using the same version
2) Is authentication applkied and is this correct
3) Acls' not blocking HRSP Hellos -
4) Layer1/2 connectivity ( vtp/stp etc.)
5) can you ping between the peers
6) ip rediracts enabled (  by default its disabled when hrsp is enabled)
Show Standby - cross check configuration
res
Paul
Kind Regards
Paul
hello I have this output.
7K-01# show hsrp interface vlan 3 detail
Vlan3 - Group 0 (HSRP-V2) (IPv4)
  Local state is Standby, priority 100 (Cfged 100), may preempt
    Forwarding threshold(for vPC), lower: 0 upper: 100
  Hellotime 3 sec, holdtime 10 sec
  Next hello sent in 0.436000 sec(s)
  Virtual IP address is 10.3.0.1 (Cfged)
  Active router is 10.3.0.3, priority 100 expires in 8.034000 sec(s)
7K-01-Remote# show hsrp interface vlan 3 detail
  Next hello sent in 1.466000 sec(s)
  Active router is 10.3.0.5, priority 100 expires in 5.879000 sec(s)
  Standby router is local
Thanks.
Hello
This looks like HRSP has peered.
Can you post the output Show standby Brief
res
paul
Kind Regards
Paul
Hello
I will get that today,
thanks.
Interface   Grp  Prio P State    Active addr      Standby addr     Group addr
  Vlan13       0    100  P Standby  10.3.0.3         local            10.3.0.1        (conf)
  Vlan132      0    100  P Standby  10.26.0.3        local            10.26.0.1       (conf)
  Vlan140      0    100  P Standby  10.99.40.3       local            10.99.40.1      (conf)
  Vlan141      0    100  P Standby  10.99.41.3       local            10.99.41.1      (conf)
  Vlan142      0    100  P Standby  10.99.42.3       local            10.99.42.1      (conf)
 Thanks.
Hello Paul,
This is the show standby brief for both sites.
 show hsrp standby brief
*:IPv6 group   #:group belongs to a bundle
                     P indicates configured to preempt.
  Vlan3       0    100  P Standby  10.3.0.3         local            10.3.0.1        (conf)
  Vlan32      0    100  P Standby  10.26.0.3        local            10.26.0.1       (conf)
  Vlan40      0    100  P Standby  10.99.40.3       local            10.99.40.1      (conf)
  Vlan41      0    100  P Standby  10.99.41.3       local            10.99.41.1      (conf)
  Vlan42      0    100  P Standby  10.99.42.3       local            10.99.42.1      (conf)
  Vlan43      0    100  P Standby  10.99.43.3       local            10.99.43.1      (conf)
  Vlan46      0    100  P Standby  10.99.46.3       local            10.99.46.1      (conf)
  Vlan55      0    100  P Standby  10.99.55.3       local            10.99.55.1      (conf)
Site 2
  Vlan3       0    100  P Standby  10.3.0.5         local            10.3.0.1        (conf)
  Vlan32      0    100  P Standby  10.26.0.5        local            10.26.0.1       (conf)
  Vlan41      0    100  P Standby  10.99.41.5       local            10.99.41.1      (conf)
  Vlan42      0    100  P Standby  10.99.42.5       local            10.99.42.1      (conf)
  Vlan43      0    100  P Standby  10.99.43.5       local            10.99.43.1      (conf)
  Vlan46      0    100  P Standby  10.99.46.5       local            10.99.46.1      (conf)
  Vlan55      0    100  P Standby  10.99.55.5       local            10.99.55.1      (conf)
Ganesh Hariharan
Just few clarification based on the output provied, Is both the switches are in normal trunk between the sites and you are running HSRP between the sites.
As per out shown for show hsrp vlan 3 that clearly shows active router and standby router without any issue.
Could you pos the HSRP configiration of the vlan 3 from both the switches as well.
-GI
