HSRP Issue with mac address not refreshing
I have an HSRP group defined between two ARS routers.  Every so ofter I will get Arp table entry confusion.  My active router may still have an arp entry that hold the mac address.  Once fail over occurs entries from the original active device is still associated to the port.  In most cases I can delete the entry.  In other situations I actually need to reboot the switch.  Is there a fix for this?
Donna
Jose Jara
Level 3
Level 3
Hello Donna,
Are you using use-bia ? Can you please post the configuration ?
Jose.
