HSRP on a interface with a crypto map
dphills18
Not sure if I am in the right section. But we are trying to run HSRP on an interface with a crypto map assigned to it. Thus, I need to get the tunnel to work with the virtual ip address. The trick with this should just be a few commands. I have done this on other devices.
interface FastEthernet0/1.1111
description VPN
encapsulation dot1Q 1111
ip address 222.222.222.3 255.255.255.224
standby 20 ip 222.222.222.3
standby 20 priority 200
standby 20 preempt delay minimum 180
standby 20 name HOU_VPN
crypto map VPN redundancy HOU_VPN
the two commands that should make this work are:
i know this tunnel is working because it works fine without HSRP and applying the VPN crypto map to the interface.
when i setup the interface like the one above, i get the following error:
%Crypto map already applied and usage inconsistant
anyone know what this may mean.
p.s.
i just notice that cisco spelled INCONSISTENT wrong. :)
Giuseppe Larosa
Hello Dwayne,
you are trying to use something in the middle between classic crypto map and stateful IPSec I was able too to use it.
I think it can be an issue with the platform and IOS release you are using.
or simply you need to remove all references to the crypto and then appy the command with the additional option
Hope to help
Giuseppe
Giuseppe Larosa
Hello Dwayne,
Hope to help
Giuseppe
i think that might be it. i looked back through the config and saw the crypto map applied to two other interfaces. i am going to try this again and let you know how it came out. thaks for your response.
