G.703 Network Termination
exonetinf1nity
Greetings, i have a BT NTU installed at one of customer sites which presents the circuit on G.703 120ohm, im looking for appropriate baluns to connect between a Cisco 2801 over Ethernet and the NTU itself.
Could someone clarify if the products below would be suitable, picture of NTU attached. I believe the connectors on the NTU are Male BNC.
G.703 Balun 2.048-Mbps, Female
http://www.blackbox.co.uk/solutions/display.asp?cs=dvh&id=1&doc=mt242a-m
Duplex G.703 Coax Cable (Siamese), 3.0-m
http://www.blackbox.co.uk/solutions/display.asp?cs=dvh&id=1&doc=etnu703-2m&tx=Cable%20Products&sx=Serial%20Cables
Giuseppe Larosa
Hello Mark,
balun are fine to connect the g.703 to an RJ-45 E1 port not ethernet port.
You need a straigh through ethernet cable with all pairs cabled to connect the E1 port to the balun RJ-45 port the two coax are connected to their connectors.
And you need two coax cables to connect the balun to the NTU.
E1 port is a serial interface not ethernet.
your choices look like correct but you need an E1 port.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Mark,
Hope to help
Giuseppe
Thank you very much for your time, the response is most helpful.
